Old 06-28-2002, 10:18 PM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Unhappy b16 problems!
Man i had to drive like 30 minutes to home with my car cause i got it towed to the muffler shop to get piping and bleed the breaks. Well i had run into hard problems. My engine keeps dieing on me. I have to keep reving the engine in order for the engine to keep running! My car also over heats and i did plug in the fan but i don't know what else to check besides my thermostat. My v-tec doesn't work either! Can someone please help me? I appreciate it! Thanks!
Old 06-29-2002, 01:57 AM
EightOhOne's Avatar
EightOhOne EightOhOne is offline
throwing any codes? check your vaccuum lines and make sure theres no leaks anywhere. did it run fine on your way to the muffler shop? if so, maybe somethings wrong with one of your o2 sensors...just some guesses..
Old 06-30-2002, 01:28 PM
shatshadarach shatshadarach is offline
did you get your o2 sensor wires mixed up...???
Old 07-01-2002, 01:14 PM
mellowboy's Avatar
I'm getting a code 3 and 5 now. So i'm not sure if its the o2 sensor? I don't think i got the wires mixed up?
Old 07-03-2002, 11:48 AM
mellowboy's Avatar
Can somebody help me please? I really need ur guys help. Thanks
Old 07-05-2002, 02:31 PM
Fishcat37's Avatar
Fishcat37 Fishcat37 is offline
Send a message via AIM to Fishcat37
when i was borrowing my friends mugen chipped ecu my car would die also if i didn't keep my foot on the gas (for a while i was braking with my left foot and keep my right foot on the gas). if you are using a chipped ecu....which i thought that you said a while ago that you would be...just adjust the two 12mm(i think) nuts on your throttle cable. this way it keep the the "foot on the gas" for you. it working for me. as far as the overheating thing goes....i had my share of the those problems....if you've already checked your thermostat and your cooling fan connections then try checking/replacing your cooling fan relay (in the fuse box in the engine bay). to find out what those the numbers are: go to the hybrid honda website for ecu trouble codes. i think the easiest way to get to it is by going to a search engine and typing in "honda ecu trouble codes". hope this way of some help sammy
FLINT BLACK 1990 CRX SI
Appearance Mods:
-JDM EF8 CR-X SiR Spoiler
-94/95 Integra GS-R rims
Performance Mods:
-JDM B18C swap
-OBD1 conversion
-Chipped P28 ECU
-Skunk2 Intake Manifold
-DC Sports 4-2-1 Header
-MSD SCI-L ignition
-EXEDY Racing Clutch
Interior Mod
-'95 Integra GS-R Gauge Cluster
Former Motors - RIP:
-JDM B16A #1- Blew up due to over-revving
-JDM B16A #2 - Hydrolocked
Former Cars
'89 CRX Si - "The Bumblebee"
'94 Integra GS-R
'96 Camaro
Old 07-06-2002, 01:16 PM
mellowboy's Avatar
Yeh thanks man. I didn't get my ecu chipped cause that guy took way too long. You know that red braided vacuum hose ? Well its not plugged in to my throttle body. Why? cause the where the hose clamps on is broken . the needle part is broken so i think i have to replace the whole throttle body. i hope this works. Thanks for ur help man i appreciate it
Old 07-06-2002, 02:21 PM
mellowboy's Avatar
Ok i just found out that code 3 and 5 are both map sensors.
Old 07-06-2002, 03:08 PM
tbk49's Avatar
tbk49 tbk49 is offline
Send a message via MSN to tbk49
how long have u have the b16 in there?
blah
Old 07-06-2002, 05:25 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
sounds like you have a vacumm leak to me, check your hoses.
also for the overheating, check that you have enough fluid inside the system, and that its properly mixed.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 07-09-2002, 02:32 PM
mellowboy's Avatar
I have the b16 in there for about 2 weeks but i hardly drive it. I think it is my vacuum leaks. My map sensor has some missing hoses so i have to go figure where all that goes.
Old 07-09-2002, 02:33 PM
mellowboy's Avatar
Oh about the antifreeze..do i have to put some on the resevoir? Some dude told me i don't need to put anything in there.
Old 07-11-2002, 10:17 AM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
im also having problems with my b16 swap. except my problems have to do with the gauge cluster not working at all, and my fan not coming on. everything else works, and i have no codes in the ECU. after my alignment and i bleed the brakes, i would really like to actually drive the car. help please
b16 problems audiophile420 Let's get Technical! 1 07-31-2004 02:45 PM
B16 problems shatshadarach '88 - '91 Civic | CRX | Wagon | Shuttlee 5 12-08-2003 06:50 PM
b16 problem!!!!! B16CrX89 Engineering/ Technical 5 11-14-2003 03:29 PM
B16 problems part 2 shatshadarach '88 - '91 Civic | CRX | Wagon | Shuttlee 3 06-04-2002 12:44 PM
B16 problems shatshadarach Engineering/ Technical 2 05-21-2002 02:22 AM
