Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 02-23-2006, 08:22 PM
studious03 studious03 is offline
True Dual Exhuast
There is a 92 caprice 5.0 with True dual exhaust at the junkyard near my house. My question is since this custom set-up is ran from the heads there is no cat just pipe and mufflers, will i fail emissions? I plan to just unbolt them from the heads and install on mine so no cutting will be done...
1993 Toyota Camry LE 2.2
1992 Chevrolet Caprice 5.0
1995 Jeep Grand Cherokee Limited 5.2
Old 02-23-2006, 09:34 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: True Dual Exhuast
If there's no cats on it, it most certainly will fail the emissions inspection - both emission and physical inspection. They will not certify it unless there are cats on it. Since the LT1 Caprice had factory true dual-cat duals, you can put a dual-cat system on it, but the cats must be present.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 02-24-2006, 03:24 PM
kahjdh's Avatar
kahjdh kahjdh is offline
Do it right after e-check so you have 2yrs until you have to worry again.
ASE Master Certified before the age of 20
Current Cars:
2001 Chevy Silverado 1500 Z71 5.3L
1996 Acura Integra LS B18 1.8L
Past Cars:
1990 Buick Estate Wagon 5.0L
1987 Chevy S10 2.5L Tec Four
1995 Pontiac Grand Am 2.3 Quad 4
1996 Jeep Grand Cherokee Limited 5.2L AWD
1991 Ford Tempo L 2.3L
1992 Buick LeSabre 3.8L
1997 Buick Century 3.1L
1996 Lumina APV GT 3.4L
2006 Ford Escape 3.0L XLT
Old 02-24-2006, 08:01 PM
Yea i will pull them from the yard tomorrow and have my emissions checked next week b4 i put them on.... will take pix....
Old 02-25-2006, 03:10 PM
Here are some pix of my find: 40 series flowmasters w/custom pipping No CATS:
Old 02-26-2006, 11:09 AM
kahjdh's Avatar
awesome score, they look alomst new too.
Current Cars:
Past Cars:
Old 02-26-2006, 11:13 AM
Thanks! i actually had to cut to remove them from the rear end, i plan to install them later this week after my emission test with not cats. will post pix of install....
Old 02-26-2006, 11:34 AM
Cyrix_2k's Avatar
Cyrix_2k Cyrix_2k is offline
How much did they cost? I have $300 in my exhaust from the cat back and it's single!
1996 BMW 318i Convertible
1989 Caprice Brougham - 305 V8, TH-2004r - FOR SOLD!!!
Old 02-26-2006, 11:42 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Do yourself and your car a favor put cats on it with the duel exhuast.
Without them Anytime you drive on a federal highway it is illegal.
Saftey checks road stops and highway emmisions checks or accidents and you will be in big trouble. They can even mail you a ticket now days after you drive by one of them emmision check machines.
And without cats and 02 sensors your car emmision and computer system will not work right. Can result in shorter engine life and less gas millage.
Do not sat we did not tell you so but it is.
Your choice.
Good Luck MT
MT
Old 02-26-2006, 08:56 PM
I got them for $70 i pulled.... i will most likely put cats on but not until my next emission check, this car will only be driven in the summer.... but thanks for your concern! Hopefully it will not rain so i can get under there.....
Old 02-28-2006, 08:26 AM
Just installed them Last night after my emission test without the cats just to see if there are any differences and i noticed very little power gain, and the temp gauge tells me that my car is overheating... Trial and error next step is to get 2 custom cats in there just so i don't have to worry about emissions and see if it will stop overheating.
Old 03-02-2006, 08:10 PM
Installed:
Old 03-03-2006, 10:38 AM
1986Z28's Avatar
1986Z28 1986Z28 is offline
Has a Camaro
Send a message via MSN to 1986Z28
nice now get rid of those crappy tail lights and put some like mine on
Formerly Blownalcoholboy
1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi)
Best ET 1/4: 8.35 @ 170mph (275 drag radial)
Best ET 1/8: 5.44 @ 132mph (275 drag radial)
Best 60': 1.31 on the back tires (275 drag radial)
AF User Rules/Guidelines
http://www.automotiveforums.com/vbul...uidelines.html
Old 03-03-2006, 10:39 AM
1986Z28's Avatar
Has a Camaro
nice looking car BTW
Old 03-03-2006, 02:20 PM
kahjdh's Avatar
nice ride, now we need a sound clip.
Current Cars:
Past Cars:
