Go Back   Automotive Forums Car Chat > Toyota > Celica
Old 02-22-2006, 01:58 PM
dfitz176 dfitz176 is offline
Send a message via Yahoo to dfitz176
reverse idler gear lock bolt fell out!
Help! I have a 89 celica ragtop and the reverse idler gear lock bolt fell out of the tranny. It rarely goes into reverse and it leaks out the hole. I bought a new bolt but how do I get it in? There is a shaft or pin that has moved and I can't move it back. Any way to do this short of removing the tranny?
Old 02-23-2006, 09:43 PM
jwaj2002 jwaj2002 is offline
Re: reverse idler gear lock bolt fell out!
get a haynes or chiltons
Old 03-27-2006, 07:14 PM
Chiltons and haynes no help. (duh) The answer turned out to be dental tools and about 4 hours worth of patients. Working thru the bolt hole with some makeshift dental tools and an icepick with heat shrink tubing on the end I finally got it back in place. The bolt then screwed right in and it all worked! Saved me about $1500-$2000 to remove and tear down the tranny! Praise God! Hope you never have this problem!
Old 04-17-2006, 01:26 AM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Good job - glad you could fix it.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
