Old 02-22-2006, 07:15 AM
unicyclemidget11 unicyclemidget11 is offline
electric cut out wires? header bolt torque?
where can i make the entry from underneath the car into the cabin of the car for the electronic cut out wires? also, what is the torque for the bolts for the exhaust manifolds? thanks
Old 02-22-2006, 09:51 AM
Re: electric cut out wires? header bolt torque?
i found my answer to the torque question. still need help on the cut out wires though
http://www.speedfreaksspeedshop.com/...idCategory=731
Old 02-22-2006, 04:20 PM
blindeyed's Avatar
blindeyed blindeyed is offline
eBay aDdict™
Send a message via AIM to blindeyed
Where are you putting the cutout at? I'm eventually going to order one for my Borla system which is already designed with with a cutout but has adapter plates. The cutout is right next to the muffler, and I found a small hole right above the rear passenger tire that I'm going to route my wires through. That location might not work for you if you're cutout is going to be located further up, but just thought I would throw in a possible idea your way.
- Jason
1995 Pontiac Firebird
User Guidelines | VB Codes Explained | AF Merchandise
"Each of us, is in the scheme of things, insignificant.
But millions of insignificant people, doing a tiny bit,
can add up to be a very significant force."
Old 02-22-2006, 08:26 PM
mercedes420 mercedes420 is offline
From underneath the car.. Get the wires up to the engine compartment.. From there go to either side, driver or passenger side, down along the body towards the door.. There you can directly have the wires enter the inside of the car ( Basically through the door jamb.. Run the wires along the ceiling side molding, and then your basically in to put the wires where you please..... I did it when I installed a system into my 1992 firebird..
Old 02-22-2006, 09:55 PM
alright, thanks. im putting the cut out right after the ypipe.
