Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 02-19-2006, 03:45 PM
Charge Charge is offline
1995 Bonneville SE stalling and other electronic woes
Hello,
I'm writing on behalf of my father's 1995 Bonneville SE(3800 NA). A while back, the car started stalling intermittently. Basically it'd lose power while driving and usually catch and immediately restart(almost stuttering...but it did completely go out). Sometimes we noticed the voltage gauge sweeping just before this would happen.
Took it to a mechanic. They replaced alternator and checked wiring. Battery was only a little over a year old and tested fine. They were not able to reproduce the problem. It occurred again, took it back. They eventually replaced the cam position sensor. Still occured intermittently(about 3-4 times a week). Car has spark and basic wiring was checked.
Now, we noticed that sometimes, when you open the door, the door chime goes off, when the key's not even in the ignition.
It's been suggested that it might be the ECM...but that's a rather expensive part. My dad already purchased a new car to replace this, but we'd like to get it running to sell off. Any ideas?
Old 02-19-2006, 08:06 PM
auto trainy auto trainy is offline
Re: 1995 Bonneville SE stalling and other electronic woes
Are you sure its the chime for keys being left in the ignition and not the lights being left on?
Old 02-19-2006, 08:15 PM
Well..the lights aren't on. It's the repetitive ding that it makes if you leave the keys in and the doors open. Fairly common on cars. But the key's not in the ignition...at all.
Old 02-19-2006, 09:15 PM
jdq jdq is offline
When was the last time you changed plugs and wires.Also check the ground behind battery and make sure it is clean.
2000 bonn ssei 155000 klm
1997 dodge caravan 92000 klm
Old 02-19-2006, 10:15 PM
Wires are about two years old. Plugs were changed by the mechanic as a tune-up while he checked it out the first time.
Battery contacts are clean. Last year they had a problem where the positive battery cable failed(the connector's screw got stripped). The whole cable was replaced at the dealership and they cleaned up the contacts on the cables. The battery is only about a year old.
Old 03-01-2006, 03:32 PM
sixsmiles sixsmiles is offline
I have a 95 Bonneville with very similar problems. Could not find the problem in the wiring and have completed extensive checks. Still looking for hope! My car will stall simply by rocking the vehicle forward and back.
Old 03-01-2006, 07:42 PM
wannano7 wannano7 is offline
My 94 Bonneville was doing this. It happened when coasting at closed throttle. It was the egr valve. A new one costs $140 to $190, but easy to change. Good luck!
Old 08-23-2006, 08:25 AM
Just to let you know I did get the car running for 20,000 miles relatively good by adding a ground wire between the Engine and Frame. Initially the resistance was 20 MOhms, with a new wire it was 5 Ohms. Hope this helps.
Old 08-23-2006, 02:01 PM
warren5555 warren5555 is offline
the part with chime, had same problem found that light switch was shorting
out and making lights chime come on but not the lights. later ended up shorting out the dash light switch so we had no lights on the dash. It was burnt and melted a little. also had simular stalling problem and it was the connector in this pic http://www.automotiveforums.com/vbul...d.php?t=599636
just cleaned no problems since. it also is a 95 se
Old 08-24-2006, 09:01 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Does the car have spark when it's acting up? It sounds like a crank position sensor to me. The battery light comes on because the engine stalled and the alternator is no longer charging. On the chime issue, do you have a big wad-o-keys hanging from the ignition? It could be the ignition cylinder is worn, and the pin that senses the key is in is worn/dirty and stuck in it's bore, cauing the chime to go off.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 08-25-2006, 10:46 AM
pamcon pamcon is offline
i have a car with very similar problems as well, but it seems that it may be heat related. the car stalls, and is unable to start again until after a cooling period. it will crank over but will not start. just replaced the electronic ignition, thinking that was it but the problem still exists.
Old 08-25-2006, 12:51 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Welcome to AF on your first post.
It would be better to start an new post on your problem.
But I will give you something to check.
First check for lose of spark or fuel preaaure or both when it does it.
And if all else fails and the fuel pressure is dropping or fuel pump quiting.
And or power windows and other stuff acting up.
Check the grounding bar under floor mat at left front door sill area.
A lot of stuff is grounded right there. Like fuel pump and power windows>
MT
MT
Old 08-25-2006, 01:19 PM
JJ052653 JJ052653 is offline
As far as the chimmer and instrument panel going dead, I found out the problem was realted to the Headlight switch. By the way, your tail lights were also effective by this bad switch. They are all related. Bet you did notice that. I filed out a complaint to the NHTB, they did care. The wires get too hot which melts the domino size connector to the switch. I have had to replace my at least 4 times. The domino size switch is about 16.00. Only the dealer carries it. You then need to purcahse, again from the dealer, the small delphia connecters. Make sure to bring in one to make sure it matches and buy a few extra. The domino size connector GM part # fior the Headlight switch is 1212-9431, buy 2, just an keep a spare. GM did I nice job of designing this junk. That part of the reason they loosing market share.
good luck.
Old 08-25-2006, 01:42 PM
thanks,i have a garage appt today.
Old 08-25-2006, 03:35 PM
jdq jdq is offline
Crank sensor usually gives problems stalling and starting when hot.
