Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 07-31-2006, 03:25 PM
emceepecks emceepecks is offline
Strange Electrical Problem
I own a 1992 Bonneville SE. The problem is that my remote to lock/unlock/trunk stopped working. Also, my electric door locks don't work and the lights don't turn on when you open the door. I checked the fuses and they are fine. Any ideas on how I can fix this?
Old 07-31-2006, 06:22 PM
Mickey#1 Mickey#1 is offline
Re: Strange Electrical Problem
That many problems at once indicates a problem with the grounds. There are two ground busses on these cars that are known to cause problems. Here's a picture of the one on the drivers side. The other is in the same location on the passenger side. Pull the metal piece from the wiring harness & clean any corrosion with sandpaper. Also clean the contacts inside the harness. I'd use a light coating of dielectric grease before putting them back together. Let us know if this helps.
Old 08-01-2006, 12:10 AM
Thanks for the reply Mickey, I'll try that tomorrow and post my results.
Old 08-04-2006, 03:27 PM
Are you sure that is the location of the ground busses in the 1992 Bonneville? I checked there on both the driver and passenger side. I found tubing containing wiring, but nothing with any kind of connectors that I could take off. Maybe I didn't look hard enough...
Do the ground busses plug into something that I maybe didn't see. What exactly should I be looking for?
Old 08-04-2006, 03:52 PM
I think that pic is from a 90 or 91. Look around a little more but if you can't find it put up a post at Bonnevilleclub.com.
http://www.bonnevilleclub.com/forum/index.php
Old 08-04-2006, 04:07 PM
Thanks for that link, I even looked a few times for a specific Bonneville forum but somehow never found that one. I'll post my problem on there and see if they know what to do. I'll post results if/when I get them
