Old 02-18-2006, 07:28 PM
Laser17 Laser17 is offline
Send a message via AIM to Laser17
Hard to start sometimes
98 3.8 intrigue, it seems like every time i get in the car the battery has barely enough power to start the car. I just got the battery replaced 3 months ago, is it possible that the alternator is not charging the battery completely?
Old 02-20-2006, 10:06 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Hard to start sometimes
Possible. Check the voltage at the battery with the car running and in off. You can go across the positive and negative terminals with a multimeter. If the alternator/charging system is good while engine is running it should read around 14 volts or no more than 17 volts. If that is good you may have what is called parasitic draw/drain which is killing the battery. Current cannot exceed 30mA depending on the reserve capacity of your battery.
Also, check the condition of all battery cables and the ground at the grounding stud located at the engine/tranny (left side engine) and to the engine compartment fuse box. Check connections on the alternator and the starter/solenoid.
Timeslip 08/12/06
AF Community Guidelines
