Old 02-18-2006, 12:43 PM
Vric's Avatar
Vric Vric is offline
Model Master Semi-Gloss Lacquer
Hi
I have a small problem that I never seen before. I used Model Master Semi-Gloss Lacquer this morning over Carbon Fiber decal and I had a strange reaction.
I don't have picture of it (I tried to fix it as quick as possible) but just imagine using a "kleenex" and rub it to the surface. It leave small white "fibre" in the paint, just like residue. I thinned it for about 2.5:1 with lacquer thinner, it sprayed nicely in my Iwata, the result while painting was great, but after few minute leaving it in a closed (dust free) compartment, it had all kind of white fibre.
If you have any idea what would have been the problem...
Thanks
Old 02-18-2006, 10:20 PM
klutz_100's Avatar
Re: Model Master Semi-Gloss Lacquer
I could be wrong Vric (probably am ) but it might be the matting agent they put in the clear?
I seem to recall reading that this is sometimes a problem with MM satin and matt finishes. Maybe its particularly visible on CF? Did you use hi-definition CF by any chance?
My 2cents
Old 02-19-2006, 09:17 AM
Vric's Avatar
Not hi Def but a dark one from SMS yes..
But I also see that problem on regular SMS carbon, less visible but it's there.
Old 02-20-2006, 02:45 AM
klutz_100's Avatar
Vric - from November last year
I thought I recalled something on this and I managed to find it - HTH
http://www.automotiveforums.com/vbul...4&postcount=11
Old 02-20-2006, 08:00 AM
Vric's Avatar
I remember this thread. But the problem in this one is a milky look (fog). I have seen this problem too, but this time it's another thing. Might be related, but it's not the exact same reaction I have. (it's not foggy everywhere, I just have "fiber" over the paint)
Thanks for the reply.
Old 02-20-2006, 02:22 PM
Ferrari TR's Avatar
Ferrari TR Ferrari TR is offline
Not A Hoarder!
Ok, your 'fuzz' is tiny bubbles.
I'm going to bet you used a decal setting or solvent solution. These contain a mild acid which does take a while to completely dissapate.
I would consider rinsing the decal with water with a little baking soda in it, then rinsing that with clear water then letting the decal air dry for several days. And then, (NO and then!) I would build the clear starting with mist coats before applying wet coats.
SCCA 7, The lost Z
Old 02-20-2006, 02:33 PM
Vric's Avatar
Thanks for the reply. I cleaned the decals with water, but maybe it wasn't enough.
It's hard to explain since I have removed everything as soon as I have seen the problem, but look at this pictures: on the right side in the black paint (not CF) you see the white stuff.
Same in the bottom left corner on this picture (on the CF)
There was a lot more like that all over the surface I painted, I removed about 98% of it.
