| Graphic Manipulation Post and discuss different automotive art works- photoshopped, 3d graphics, and hand-drawn. |
help please!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
ok i have been in and out of photshop for a while now and i was in a mood today to do one. so i got a pic of the new mugen integra type r and lowered it and experimented with coloring the hood to look carbon fiber. (its not very good) but when i wanted to go back and airbrush the wheel wells the airbrush wont work. can somebody help me with this? and also after u lower it how do u get that gray at the top of the pic to dissapeer where it wont show up in ur pic? here is a pic:
ill try again:
ok well it wont come up but can u still answer my question?
Probably because you still have something selected elsewhere. When you have a selection, changes will only take place within the selected area. Or perhaps you or on a different layer, or perhaps the opacity of your airbrush is set to 0%. Play with those things and maybe that will help.
Okay, about the air-brush question. Does it give you a circle with a line through it for a cursor when you try to use it? Or, if you have an area of the picture selected, the airbrush will only paint inside the selected area, so make sure the area you're trying to airbrush is selected, or that there are no selections at all.
As far as the grey portion at the top of the image, the easiest fix is to use the square selection tool, select everything except the grey area, and choose "crop" from the image menue. This will change the dimensions of the image though. What I usually do to lower a car is make a selection of the car's body, copy it to another layer and move the copied portion down. Then, I use the stamp/clone tool to remove the original car outline from behind the new one. As for making a carbon fiber hood, there's a good tutorial for doing that on www.geocities.com/bryces22/
ok thaknks that did it i just didnt know i had to select the peice i wnated to paint
You don't have to select the piece you want to paint. As long as nothing is selected, all the tools will work anywhere on the image, but if an area is selected, that will be the only affected area.
This comes in really handy when you want a nice clean edge, you just select the area you want to paint and then hit it with the airbrush or whatever...
