Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 02-13-2006, 11:30 PM
Broke College Kid Broke College Kid is offline
Exclamation Could anyone help me please?
I recently inherited a 91 Caprice Classic from my great grandfather. The car is in pretty good shape. It has 101k miles, and few dints and dings but no rust. The car is equipped with a keyless entry system which no longer works. I’ve changed the battery in the transmitter with no luck. Could it be the receiver? Where is the receiver? Is it the thing in the blue thing in the defrost vent? Another problem the car has is with the radio. When it is turned on it makes an ear piercing high pitched screech no matter if it is on am or fm, every station and with a tape in. What could be the problem? The driver’s side window is also off the track, how could I fix that? I’m at a loss. Could I fix any of these problems myself? Any help or repair suggestions would GREATLY be appreciated
Cody
Old 02-13-2006, 11:40 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Could anyone help me please?
The window should be fairly easy if you get the door panels pulled off - it's likely the regulator tape somehow disconnected from the glass. On my car, it was a bolt at the bottom of the door on the regulator tape track that had come off, allowing the door to simply fall off the regulator. The regulator tape is that plastic belt-like thing that has the holes in it.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 02-13-2006, 11:50 PM
Wow!! You're fast, thanks I'll check that out this weekend and report back.
Thanks,
Cody
Old 02-21-2006, 08:47 PM
GranniesCaprice GranniesCaprice is offline
As far as the radio distortion you're hearing, its the radio itself. Mine did the same thing. I actually inherited my 91' from my Grandma. You have to replace the radio with a new one to get the distortion away. So, at least you can get a CD player.
Old 02-22-2006, 03:34 PM
1986Z28's Avatar
1986Z28 1986Z28 is offline
Has a Camaro
Send a message via MSN to 1986Z28
or go to a junkyard and get a stock stereo
Formerly Blownalcoholboy
1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi)
Best ET 1/4: 8.35 @ 170mph (275 drag radial)
Best ET 1/8: 5.44 @ 132mph (275 drag radial)
Best 60': 1.31 on the back tires (275 drag radial)
AF User Rules/Guidelines
http://www.automotiveforums.com/vbul...uidelines.html
Old 02-22-2006, 05:04 PM
ilgoldstein's Avatar
ilgoldstein ilgoldstein is offline
For the window, you might want to look at this:
http://impalassforum.com/tech/interi...wfix/index.htm
There are other sites that explain the proceedure too.
Old 02-22-2006, 05:27 PM
I have tried a couple of different stereos from salvage yards to no avail, always the same high-pitched screech. If you wait long enough you can barely hear the radio over the screech. It only comes from the back speakers; I have also tried switching out the amp in the trunk with no luck.
Old 02-24-2006, 03:05 PM
1986Z28's Avatar
Has a Camaro
oh if you have an amp in the trunk you most likely have the bose system, if its onyl comeing from the rear speakers its probaly the amp thats screwed, good luck finding any parts for that bose system, they arnt very easy to come by
Old 02-24-2006, 06:07 PM
Cyrix_2k's Avatar
Cyrix_2k Cyrix_2k is offline
yeah, just replace all that junk with aftermarket stuff.
1996 BMW 318i Convertible
1989 Caprice Brougham - 305 V8, TH-2004r - FOR SOLD!!!
