Go Back   Automotive Forums Car Chat > Honda > Del Sol
Old 02-11-2006, 01:38 AM
d4h8a1's Avatar
d4h8a1 d4h8a1 is offline
Send a message via Yahoo to d4h8a1
93 syncro problem
I have a '93 del sol non vtec, sohc. I replaced the tranny fluid the other day. Every time i shift into third gear I hear that god aweful noise of grinding gears. I want to know if it is a characteristic failure of 93 models, or if mine has just been abused. It does have 128 thousand miles on it...
Also, is it true that the 93 model does not have a low gas indecator light?
Old 02-12-2006, 12:56 PM
AudioGuy93DelSol's Avatar
AudioGuy93DelSol AudioGuy93DelSol is offline
NA is Best!
Send a message via AIM to AudioGuy93DelSol
Re: 93 syncro problem
What weight oil did you put in your trans? And it's true that your 93 does not have a low gas indicator light.
Oil leak? What oil leak? That puddle under the car is just sweat from all that horsepower.
"How many NASCAR passes is that worth? 500?" (Schumacher passing Raikkonen)
Emily is amazing, and she messed with my sig AGAIN!
Old 02-13-2006, 12:56 AM
d4h8a1's Avatar
I used the honda factory stuff. Not exactly sure what weight though.
Old 02-13-2006, 08:10 PM
NA is Best!
Ok, so it didn't grind before the oil change and now it does, or are you saying that you were trying to fix the grind by changing the trans oil and it didn't work?
Old 02-13-2006, 09:16 PM
d4h8a1's Avatar
Yeah, the tranny was grinding into 3rd, but it needed the axel seals replaced too. I replaced the seals and filled the tranny with new fluid. It still grinds into 3rd.
Old 02-14-2006, 03:43 PM
NA is Best!
Then yes, it could very well be the syncros. Before you go buying a new trans, check your linkage. If it's loose or damaged it could not be fully engaging 3rd gear causing the grind.
Old 02-16-2006, 03:01 AM
b16adelsol b16adelsol is offline
what do you guys mean by low gas indicator light? because i also have a 93 del sol... i wonder what that is..
Old 02-19-2006, 01:17 PM
NA is Best!
The light that comes on when your gas is low. Most cars have them, 93 sol's didn't. Oh no, we have to read a guage?!
