Go Back   Automotive Forums Car Chat > Ford > Aerostar
Old 06-23-2002, 10:49 AM
fordaero fordaero is offline
Question mmissing aerostar
! have a 86 ford arostar. Ugly but runs great, until last week while heading home, doing 65 mph down the hiway when it started to run rough. I replaced wires, cap, rotor, front four spark plugs. lookig for cheap fix. Any help?
Old 07-01-2002, 12:58 AM
TerminalVelocity's Avatar
TerminalVelocity TerminalVelocity is offline
Send a message via AIM to TerminalVelocity
fuel filter?
My new RHD project!
Solid Crew (Circa 2002)
Old 09-24-2002, 06:25 AM
Cbass's Avatar
Cbass Cbass is offline
Send a message via ICQ to Cbass Send a message via AIM to Cbass Send a message via MSN to Cbass Send a message via Yahoo to Cbass
I've got an 86 too... do you have the 2.8 or 3.0? They also had the 2.3 I think...
Connor - Porsche Nazi since 2001, VW defiler since 2004
This here's a Fabrication forum!
My lugnut requires more torque than your LS1 makes.
Old 10-10-2003, 01:59 AM
hawkeye2100 hawkeye2100 is offline
2.3l FI 140 CID VIN A O.H.C.- SOHC,
2.8l 2BBL 171 CID VIN S O.H.V,
3.0l FI 182 CID VIN U O.H.V. which one do you have??
Old 11-16-2003, 06:56 PM
ace_mechanic71's Avatar
ace_mechanic71 ace_mechanic71 is offline
Send a message via Yahoo to ace_mechanic71
Try changing the last 2 spark plugs, if that doesnt work then unsnap all 6 sparkplug wires from the plugs but let them still touch and start the van. One by one with a set of plastic pliers pull off each plug wire until all 6 are done. You are listening for a change each time. If it doesnt change then you have a bad wire, or posibly a bad plug, or cap. And yes I have done this before, I never said it was going to be easy. Those back 2 plugs are hard to get to. Good luck!
