| Engineering/ Technical Ask technical questions about cars. Do you know how a car engine works? |
The first actual question
EGR in diesels.
Do some engines use it? If not why? You would think it would help because the increased heat would help combustion, and there is always air in the diesel exhaust (at least on stock diesels). so wouldn't it add power and fuel economy? |
Re: The first actual question
Yes.
EGR reduces combustion heat. The dilution of the intake charge with exhaust reduces heat. Its main focus (on gas and diesel) is to lower combustion temps in an effort to reduce NOx emissions.
The higher compression of diesel engines typically makes a lot more NOx than gas, so EGR is almost a necessity. Newer diesel EGR are intercooled to prevent adding extra heat which further reduces NOx. I think all deisels produced after about 1980 have EGR.
Dragging people kicking and screaming into the enlightenment. |
yes, and unfortunately, on some vehilces the egr cause more problems --they get clogged and don't self clean, throwing a CEL on the dash with some stupid codes. ugh!
99 passport 3.2L v6 DOHC auto-trans 4x4 modified IFS 10 bolt front/ dana 44 4.10 rear ![]() ![]() ![]() SKYWARN we be clubbin' --B |
egr is a disaster if you are looking for performance disable that one. CAT didn't put egr on their new OTR truck engines because of the problems instead they paid the EPA a fine for every motor with out and have less problems.
2005 Ford F350 6.0 Lariat CC SB, Bully Dog custom tuning, 4 inch straight pipe, ATS Diesel stage 5 transmission 120hp custom injectors, heads, studs, water-methanol injection, O-Ringed by Piers Diesel 575hp 1091lb-ft at the wheels 1941 Willys Americar 2door Coupe STOCK AND CLASSIC |
CAT has the ACERT system now that meets 2004 EPA standards. Cummins, Detroit, International-Harvester... everybody else basically went to a cooled EGR system to meet 2004 EPA emissions standards
