Old 06-20-2002, 03:28 PM
toussi1 toussi1 is offline
How to remove front headlights 2000ex
I removed the two bolts on top of the headlight, but it still won't come off. What else must i do.
Old 06-20-2002, 04:13 PM
HamsterStyle HamsterStyle is offline
Send a message via AIM to HamsterStyle
there should still be at least one bolt on there but i think there is one on the side and one on the bottom im not sure though
Original PH member since May 2000.
Old 06-20-2002, 05:22 PM
rockerdude rockerdude is offline
make sure to take the bumper off to access the bottom bolts, there should be 3 on top, 1 on the side, and 2 on the bottom, if i'm correct, i forgot since i last remove my headlights 3 months ago.
Old 06-20-2002, 09:30 PM
I have to do all that work to install and set of headlight bulbs. Now how do you take out the bumper?
Old 06-20-2002, 09:55 PM
JuMBoBeaTS's Avatar
JuMBoBeaTS JuMBoBeaTS is offline
Send a message via AIM to JuMBoBeaTS
wait wait... bulbs? just reach behind the headlight... remove the power wires... its a lil box... then remove the rubber seal... unhook the bulb harness... then remove the bulb... work wid gloves... cuz theres electrical grease all over the prongs of the bulb... becareful not to touch the bulb... dirt can cause the bulb to pop... oh yeah... the driver side headlight is a BITCH... theres alot in the way... i had to fabricate a tool to re-hook the harness... i got short fingers... lol good luck... u shudda told us that u were just replacin bulbs... check your owners manual if u need visual aids...
2000 honda civic EX 2dr black
Turbo Future...
Old 06-22-2002, 05:29 PM
the driver side ain't too bad. just lift the power steering reservoir off its holder and youre in like flint
problem removing old headlight erratic Galant 0 10-17-2010 01:33 PM
How to remove headlight LENS on 1999 Grand Marquis LieutenantCracker Grand Marquis 0 01-29-2010 10:53 PM
HOW TO: Remove Front/Rear Dash and Install Deck, Remove Door Panels Classicrocjunkie Non-Performance 157 04-25-2009 10:39 AM
How to remove the headlight bulb B.B. Accord/TSX/Accord Hybrid 2 03-03-2004 11:08 PM
Remove Tahoe Headlights....How?? Please! SRP59 C/K 2 12-04-2003 11:14 PM
