Old 12-02-2003, 09:52 PM
SRP59 SRP59 is offline
Question Remove Tahoe Headlights....How?? Please!
I just acquired a great -95 Tahoe LS with the four headlamp/composite system, and I'd like to install upgraded halogen bulbs. I cannot reach 3 out of the 4 bulbs.
Is there a relatively easy way to pull the entire light assembly out from the front? Any help would be GREATLY appreciated!
Old 12-04-2003, 09:00 PM
jgood2709 jgood2709 is offline
Send a message via AIM to jgood2709
pop the hood, there should be two metal rods sticking up above each headlight, get a wrench and loosen them. when it's loose, the whole rod comes out. then you can just wiggle out the headlight housing. you can access the bulbs from the back of the housing. release and pull off the power cord for the bulb, then twist the bulb and pull it out. good luck.
Old 12-04-2003, 11:14 PM
Thumbs up Re: Remove Tahoe Headlights....How?? Please!
Hey jgood! Thanks a million for the info...Sounds easy enough...I'll give it a shot tomorrow!
