Old 02-02-2006, 08:11 PM
gaelic gaelic is offline
help
i have a 95 which wont start its a 4.3 vortec engine i tried to turn the engine over manually but it wont budge any ideas how to get it to move would really help thanks
Old 02-03-2006, 02:05 AM
Rmbodie's Avatar
Rmbodie Rmbodie is offline
Re: help
When you say manually , you mean with a large socket on the front of the main crank at the harmonic balancer , right ? You can remove all the plugs to eliminate the posibility of hydralock . that would be my next step . If you can't turn it then , You have either a component on the assessory drive locked up , a bearing spun and locked on the crank , or the starter is engaged and locked with the flywheel . I think I covered all the posibilities.
Hope this helps. Rob
2000 Trans Am six speed Blackbird .Fast enough stock!
2005 Grand Prix.
2005 2500HD Silverado 4x4 , Duramax!!!!!!! Lifted ,Pumped,Humped,Thumped!
1988 JEEP Cherokee: Lifted, Sons new toy.
Old 02-03-2006, 08:15 AM
Re: help
i removed all the plugs and it still wont budge what else would you suggest
Old 02-03-2006, 08:47 AM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: help
Spray some penetrating oil (not WD40) into the cylinders through the spark plug holes, let it sit overnight. You can then put a wooden dowel into the cylinders and gently tap the top of the pistons by tapping the dowel with a hammer to try and free the rings (if that is your problem).
Good luck.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 02-03-2006, 09:56 AM
herkyhawki herkyhawki is offline
Re: help
and take the belt off
Old 02-03-2006, 07:28 PM
Re: help
thanks guys i will try that on saturday hopefully it will work
Old 02-04-2006, 06:40 PM
y2kblazer y2kblazer is offline
Re: help
has the truck been sitting- if so how long, or did it just not turn over one day?
Old 02-04-2006, 09:17 PM
Re: help
its been sitting for about six months
Old 02-06-2006, 12:12 AM
Rmbodie's Avatar
Re: help
That would have been good info at the beginning. Probably locked because of rust . Garage or outside storage ? no matter, Cylinder walls probably coated with rust
2005 Grand Prix.
Old 02-06-2006, 07:37 PM
Re: help
or..........dead battery?............
Old 02-06-2006, 07:45 PM
billibong's Avatar
billibong billibong is offline
Re: help
Dead battery wouldn't matter if he were trying to manually turn the crank.
Try what Brian R. said, and spray it down with a penetrating oil. But I would have to agree with Rmbodie, it is probably rusted up.
billibong
99 4X4 Blazer LS Vin W
Repairs:
U/L Ball Joints, I/O Tie Rod Ends, New Tie Rod Adjusting Sleeves, New Idler Arm, R & L Front Hubs, R & L Upper CA Bushings, New Gabriel Ultramax Shocks (what a difference)
F & R Brakes and Rotors at 110,000.
Infinity Speakers to replace the blown factory sets.
162K+ and still kicking.
