Old 02-02-2006, 02:21 PM
Jaymes's Avatar
Jaymes Jaymes is offline
Wheel arches
Any else also notice that the wheel arches in most models are too wide and not accurate at all??? Even the biggest rims don't seem to fill up the damn arches and there's always gaps on the sides.
Old 02-02-2006, 09:28 PM
freakray freakray is offline
AF Modelrater
Re: Wheel arches
Fujimi?
AF User Guidelines
Old 02-02-2006, 10:03 PM
hirofkd's Avatar
hirofkd hirofkd is offline
Re: Wheel arches
What kind of world do you live? Never heard of cars with a suspension stroke?
Well, I see your point though. The fact of the matter is that human eyes don't register a 4500 mm long real car and a 190 mm long model car the same way. If a certain car is reduced to a miniature size "accurately," the body will look too narrow, and the tires & wheels will look much smaller than you'd think. Company like Tamiya tends to exaggerate certain features so that their models look better. Case in point? See their 911 Turbo kit? Wheels aren't that bit on the real car. What about their FD kit? The body is ungodly inaccurate compared to the ones of Aoshima, Rosso and Fujimi.
Fujimi has a series called "inch-up," and as the name suggests, they (are supposed to) represent wheel sizes bigger by 1 inch. The problem is, it seems that Fujimi has forgotten the meaning of the series, and some wheels are rather "accurate," even if it's in the Inch-Up series. Their NSX has accurate wheel diameter, but as a result, they look too small. (Stick to the principle of your own product line, Fujimi!)
In reality, tires look much smaller. Just pay attention to the gap between the wheel arch and the tires of an unmodified Mustang or something in your neighborhood, and you'll be surprised.
Hiroaki Fukuda
Old 02-02-2006, 10:13 PM
blubaja's Avatar
blubaja blubaja is offline
Re: Wheel arches
It's called wheelgap. Subarus tend to have the Fujimi syndrome sometimes. Well, modified ones. Like this beauty
Old 02-02-2006, 11:59 PM
Jaymes's Avatar
Re: Wheel arches
No, I'm talking about the sides of the wheel arches
Judge for yourself
Old 02-03-2006, 01:06 AM
bhop73's Avatar
bhop73 bhop73 is offline
Re: Wheel arches
Judge for yourself
The Z model looks 100% accurate to me... well, maybe 99%
http://www.bhop73.com/
Old 02-03-2006, 06:28 AM
generationx's Avatar
generationx generationx is offline
Re: Wheel arches
hirofkd has it right of course. In "real life" cars need suspension travel to give handling and comfort. Just look at a Ford Focus or similar family saloon. Even tarmac-spec rally cars have large wheel arch gaps, mainly to allow good wheel travel, especially while turned for corners.
It is just that the reality doesn't look so good on a scale model...
Old 02-03-2006, 02:53 PM
Jaymes's Avatar
Re: Wheel arches
Judge for yourself
I drew lines
Old 02-03-2006, 03:53 PM
356speedster 356speedster is offline
Re: Wheel arches
The modelcar wheel is too small.
Measure the with of the bottom of the wheelarches on both pictures and the diameter of the wheels on both pics, and then make a "cross calculation" you find that the modelcar wheel is about 8 percent smaller than the wheel on the real car.
Rough calculations meassured from the pictures:
REAL CAR:
Wheel arch = RA = 34 mm
Wheel dia = RW = 31 mm
MODEL CAR
Wheel arch = MA = 38 mm
Wheel dia = MW = 32 mm
"Cross calculation"
(MAxRW)/RA = 34,6 mm = the size the model wheell should have been on the picture to be acordingly the same size as the whell on the pic of the real car.
Then the model car is also lowered way too much (compare ride height on sideskirts) so with a bigger wheel sitting lower it would fill out the with of the wheelarch almost as much as on the real car.
End of class :-)
---356 speedster---
Trying again! - Links to the old wip's (still searching for the old pics): 911 Turbo '88 - Fiat barchetta- Lotus Elan 26R - 928 S4 - 944 turbo - 924 turbo
Old 02-03-2006, 06:20 PM
AF Modelrater
Re: Wheel arches
That's a '98 RS, I had the same year & model and mine never sat that high.
AF User Guidelines
