Old 06-19-2002, 08:34 PM
Sean Price Sean Price is offline
Send a message via AIM to Sean Price Send a message via Yahoo to Sean Price
Is hot HU normal???
I just installed an alpine deck(35 x 4) in my honda civic 2000 sedan ex
I bought the wire harness and all that stuff straight from circuit city and just plugged it right in without messing with the wires or anything like that....
Now I notice that the whole unit is giving off a lot of heat? is this normal because I was bumpin pretty loud, or should I be concerned?
thanks for all
Sean Price
keepin it real/packin steeL/gettin high/cuz life's a b*tch and then u die....
Old 06-19-2002, 08:59 PM
xivera's Avatar
xivera xivera is offline
With "high powered" decks, this is common.
For example, take my Pioneer HU... Before I decided to amplify my tunes, the unit would get very warm when I'd play it very loud.
It's a head unit design problem/hurdle... for any manufacturer's engineers. They're trying to do so much w/ limited space. To pump out more power/sounds efficiently, would warrant an outside amplifier.
I/H/E, I.C.E. & other stuff...
Toni/y v0.2|Nice cars thru my lens...
Your first mod = HELMS MANUAL!!!
Old 06-19-2002, 10:13 PM
93speed's Avatar
93speed 93speed is offline
I wouldnt' worry about it unless its melting plastic, smoking, or shooting out flames Those internal parts get reeeal hot when you're pumping out that much juice. All that heat can't escape very well when its crammed in a dash. A little heat is normal but if it gets super hot to where you can't touch it or causes other problems I start to get concerned.
Old 06-19-2002, 10:58 PM
Civic98 Civic98 is offline
Send a message via AIM to Civic98
yeah...a little heat won't harm anything.....unless if it's really hot
Old 06-19-2002, 10:59 PM
yeah...a little heat won't harm anything.....unless if it's really hot......happens to me too
Old 06-19-2002, 11:59 PM
GSteg's Avatar
GSteg GSteg is offline
Send a message via AIM to GSteg
my pioneer headunit use to do that. i get rid of the heat by powering the speakers with an external amp rather than the headunit. plus, i get better sound quality at high volumes.
Old 06-20-2002, 10:52 AM
tsunamiHB tsunamiHB is offline
the new alpines.....60x4...
it says in the manual to be very careful when removing the face plate cause you can burn your self on the connections.... and when i take a CD out after long hard play the CD almost burns me..LOL.... but it never shuts down on me... I cant wait to get external amps for my speakers...
Drivin a 99 Purp HB
Old 06-20-2002, 02:34 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
i played my old pioneer deck real loud when i first got it, i guess thats why it burst into flames
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 06-20-2002, 02:52 PM
GSteg's Avatar
seems like most of the pioneers i have owned was close to being burst into flames
Old 06-23-2002, 07:45 PM
thanks for all the heads up on the HU...
now my second deal is this, my HU won't keep the time? every time I restart my ride after a couple of hours the time is all screwed up?
as I said before as far as the wire harness and all that goes I just plugged it into the HU and into the car, without changing any of the wiring, just out the package and into the car?
was that the correct process or did I have to mess with the wiring for my specfic car?
thanks
Sean Price
Old 06-23-2002, 07:59 PM
GSteg's Avatar
i would personally upgrade your 12+ constant battery wire and ground wire into something bigger. stock ones won't keep up with aftermarket HU needs.. wire the constant battery wire directly to the battery and wire the ground into a nice chunk of metal bolt or floor(something metal). trust me on this. it's dangerous to go with stock wiring because they cause too much resistance and the wire heats up bad. how do i know? i did that last time and the rubber coating of the wire melted and smoke started coming out from under the dash.
1999 cherokee 4.0 running hot....sorta wkumale Cherokee 11 09-15-2010 09:05 AM
1995 4L80 no first gear when hot jems15 Commercial Trucks 1 07-11-2010 07:48 PM
Isuzu Rodeo Runs HOt WNathan67 Rodeo | Passport | MU 1 07-03-2010 08:29 PM
1992 Century won't start sometimes when hot olopezm Century 3 06-04-2010 07:56 AM
is it normal for a Saturn to run kind of hot????? joyrider SC/SL/SW 16 04-21-2005 09:50 PM
