Go Back   Automotive Forums Car Chat > Buick > Century
Old 06-01-2010, 10:52 AM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
1992 Century won't start sometimes when hot
Hello people, my uncle's '92 century will start in the morning but sometimes after the engine has warmed up if you turn the engine off, go shopping and try to start the car again all the lights in the dashboard will work and will act like the car is trying to start but there is no cranking noise, I've run a cable and a switch from the battery straight to the starter motor and this is a temporary fix, I guess there must be something wrong under the dashboard. What do you people think?
Thanks in advance.
Old 06-02-2010, 08:27 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: 1992 Century won't start sometimes when hot
sounds like a possible out of adjustment ignition switch. The switch is mounted on the top of the steering column, and is activated by a rod that runs from the key cylinder. The mounting holes are slotted and can become misaligned with age causing your symptoms.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 06-02-2010, 10:20 PM
olopezm's Avatar
Thanks richtazz, how should I re-adjust the switch? Do I need to take down the hole column or will it be possible if I only remove a plastic cover, the ignition switch or something else?.
Thanks...
Old 06-04-2010, 07:56 AM
richtazz's Avatar
if you remove the lower dash cover, you may be able to get to the 2 mounting screws without dropping the column down.
Tags
dashboard , engine , hot , starter
