Hey guys, Hopefully I have enough information to post on this...
I have a 2000/GTP 108K. DHP v1, 3.4, and supporting mods(exhaust, plugs, thermo...). While under a light load or cruising i feel a hesitation from the car. Not quite a mis-fire, more of like a cough i guess. It happens anywhere from 1500-2500 RPM and about 20-50% throttle. It is not a consistent stutter, by this i mean it doesn't do it all the time. Sometimes it is more pronounced than others. If the car stutters around a shift point then it surges pretty bad, if it stutters around 2K while cruising it isn't as bad. I scanned the car on a 4 hour drive yesterday. The only codes i have are fan codes b/c of my overide switch. I did notice that sometimes I get upwards of 3* KR while cruising if the car stutters. other than that no KR. I think that when the car stutters, sometimes it is hard enough to make something rattle and cause false knock. Then I thought about the Knock being what's causing the surging, but sometimes the surge doesn't have knock. The ECT never went above 185*, IAT was 66-73*. I checked all my vacuum lines and everything seems ok there (A/M boost gauge and the stutters occured around 8psi - 0 psi vac). Checked all the fluids (thinking maybe tranny) but everything was clean and full. Tranny was done about 25K ago, oil about 2K, coolant 40K maybe. The weirdest thing is, when I cruise at 80-85 mph, the car rides fine...but only that high of speed. I have not checked plugs yet b/c I haven't had a chance (but I am carrying an extra set + tools JIC )I really need to figure out what this it, I have to drive my car for work and I put ALOT of miles on it...It really blows! EDIT: Right after I posted this message I started my car to warm it up. After it warmed up for a few minutes it started making this awful grinding sound while it park. When I shifted out of park, the grinding stopped, back into park it started again...Is this my tranny about to go boom? EDIT 2: My Tranny Went Boom! nothing in drive, nothing reverse... Last edited by KX2000GTP; 01-30-2006 at 01:05 PM. |
Re: Hesitation and Stuttering while cruising...
Hi Jake. Out of curiosity what brand and heat range plugs are you using? Also, are you using the AC Delco 7mm wires?
GM recently put out a TSB concerning a slight "chuggle" effect. It can even be defined as a burp or cough. It says it is not the tranny either like TCC lock/unlock. Dealers cannot detect the problem on a Tech II machine either. The TSB says to check into the throttle position sensor (TPS) if basic tune up items are not the cause. This is more applicable to 2000 and up GTPs. I had a similar problem a few years back and it turned out that one spark plug had a hairline crack in the ceramic part of the electrode. Here is the link to the TSB but it covers '97 - '03: http://www.alldata.com/tsb/General-M...4-058/581.html
But Seriously....My tranny went, the car won't move...Should I buy a new one, or attempt to rebuild myself?
Hard choice. ![]()
I have the Taylor race wires... |
I'll refer you to Troy1. He is a good tranny tech with a GT and maybe he can weigh-in. Lots of experience with the 4T65E.
I'm thinking that either way, I am going to upgrade, i need to anyway if I plan to actually mod my car with something other than bolt ons so...ZZP here we come
Thanks Bob! |
$2400 is possible but expensive for a total overhaul. If you checkout EBay and search for "4T65E", there are companies that sell remanufactured ones. Once they get the old one back the core charge will be refunded. So you can get one as low as $895 and shipping round trip will run about $400. Also, you get a warranty. I would recommend the ZZP tranny if you have a modded GT or GTP. I know guys able to take it well into the high 11s on quarter mile ETs with a high degree of reliability versus stock. The ZZP reworked is much better than the 4T65E-HD.
OK.....well....thats about all I need to hear. If I am gonna bust that kinda cash...I want to get a good solid tranny. Why would I spend 2400 to get the same POS I have now when I can get a bad boy for less?
The guy at the shop said he would do an R&R for 450.00. Is that a decent cost? And to make sure I am on the same page as you....you meant an R&R of the tranny only...not going inside and rebuilding...right? |
Car was ready the next day. No core charge because we went in person. The 4T65E trannies drop like flies in that part of the country so it makes sense to have a tranny center there.
LOL.....nice!! Ok...well think I am gonna take him up on the deal.....will start saving my pennies.
By the way......only mods I have now are good plugs and 8mm accel wires. I will mod it after I get the tranny done. I knew better than to mod it before hand.....now, time for the goodies! Ern |
Hey, Dont move anymore huh? that sucks! R&R I think is about 6-8hrs. It would be tough to do on your back in the dirve way. the easiest way would be to pull the engine and tranny as one then seperate them. If you get a rebuild just ask them if the put all new bearing in 4T65E's have some cheap bearings and ofcourse the notroius PCS and 4th clutch shaft.
Well...I'm thinking about towing my car to ZZP and let them rebuild mine, that way the tranny will match the car and it would be rebuilt by the best. I figured if I have to come off with taht kinda $$$ for the tranny, then since ZZP is going to build it, they should put it in.
Only problem, its' a 12 hour drive from ATL! Gonna figure it out in the next few days here. |
