Old 01-27-2006, 10:27 AM
coopns coopns is offline
How do I change the t-stat?
95 Ford Taurus, 166k. Just replaced the water pump and she is running a bit hot, fan coming on a bit more then usual. Is it difficult to change the termostat? Where is it?
Keep'er simple I am pretty new.
Thanks.
Old 01-27-2006, 10:56 AM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: How do I change the t-stat?
Follow top radiator to where it connects to the engine. There is a metal housing that bolts to the engine. Remove the bolts that hold the housing to engine. The thermostat is inside the housing. Remove, install new one, (pay attention to how it is installed, make sure it is installed the same way the old one came out)attach housing back to engine, fill with coolant and check for leaks.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 01-27-2006, 11:39 AM
Thanks. I will giv'er a try.
Old 01-27-2006, 11:50 AM
way2old's Avatar
TOKEN HILLBILLY
Also check to see if there is a gasket under the housing or an "O" ring. These will need to be purchased separately.
