Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 01-23-2006, 05:55 PM
copcarcrzy copcarcrzy is offline
Help with Condensation problem...
I don't drive my car very often, but when I do I notice condensation on the back lid of the trunk inside as well as the fender wheel wells inside. Is this a common problem with a 1990 caprice 9c1? How do I fix this problem?
Old 01-23-2006, 06:03 PM
CD Smalley CD Smalley is offline
Re: Help with Condensation problem...
Common problem. Replace the gasket.
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Recently updated: http://forums.b-body.org
Old 01-23-2006, 08:13 PM
Thanks....Guess I'll get myself a gasket.
Old 01-23-2006, 10:08 PM
88capriceclassic 88capriceclassic is offline
yea i had a leak in my 88 and i found the leak and siliconed it and it hasnt leaked since but where is the gasket at??
Old 01-24-2006, 12:40 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
The gasket is that big black rubber ring along the edges of the opening.
Old 01-24-2006, 12:51 PM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
Another way to rid the moisture in the trunk before,(or even after you replace the gasket,) is the use of a desiccant. These are usually made up of silica gel and absorb many times their weight in moisture. You probably have seen one form or another in use in the packaging of electronics, pharmacueticals, and even shoes.They are the little packets that fall out when you open the package. Some people use these when storing their vehicles for any length of time in humid conditions, or where there may be wide temperature swings, to control moisture buildup within their vehicle.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
Old 01-24-2006, 06:47 PM
silicon212's Avatar
Confoundingly Lucid
A little trick is to use cat litter. It makes a good dessicant.
Old 01-24-2006, 06:49 PM
I dont want to soak up the moisture.. I want to STOP it
Old 01-24-2006, 07:09 PM
HLandin's Avatar
HLandin HLandin is offline
I had a similar problem with my white '90 9c1. Problem fixed itself when I replaced my CB mount with one that better fit the hole (I think it sealed better). Anyways, after the change, no more moisture problem in that car until I lost it in the accident. So my guess would be, there is some kind of leak which allows the moisture (or moist air) into the trunk and allows it to accumulate and condense.
If it is a leak, it may not be the gasket. A '89 Caprice 9c1 I was looking at lately had the same moisture problem in the trunk, but the gasket was in perfect condition, so the leak must have been somewhere else from what I can gather (although I couldn't figure out where).
Old 01-24-2006, 07:43 PM
Cyrix_2k's Avatar
Cyrix_2k Cyrix_2k is offline
I had a leak in my trunk at the front corners. I swear it was leaking through the joint. The gasket was fine so I just sealed that joint with RTV sealent. Problem fixed.
1996 BMW 318i Convertible
1989 Caprice Brougham - 305 V8, TH-2004r - FOR SOLD!!!
Old 01-25-2006, 09:37 AM
1986Z28's Avatar
1986Z28 1986Z28 is offline
Has a Camaro
Send a message via MSN to 1986Z28
stop growing marijuana in the back of the car =)
Formerly Blownalcoholboy
1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi)
Best ET 1/4: 8.35 @ 170mph (275 drag radial)
Best ET 1/8: 5.44 @ 132mph (275 drag radial)
Best 60': 1.31 on the back tires (275 drag radial)
AF User Rules/Guidelines
http://www.automotiveforums.com/vbul...uidelines.html
Old 01-25-2006, 01:51 PM
Actually you do want to soak up any remaining moisture even after you seal any leaks. Any moisture that is trapped and remains behind even after the repair can cause a host of problems including mold, mildew and rust, even in the areas of the trunk you can't see. It's a two-step process. 1) seal the trunk to stop moisture from getting in, and 2) remove what moisture is already there previous to the repair.
Old 01-25-2006, 04:10 PM
Thats ture, never thought of it
