Go Back   Automotive Forums Car Chat > Buick > Regal
Old 01-23-2006, 10:33 AM
MZSEE8 MZSEE8 is offline
Thumbs up 1999-2000 Buick Regal Keyless Entry Remote (INSTRUCTIONS INCLUDED BELOW)
Just to inform people on Automotive Forums, I bought a 2000 Buick Regal Keyless Remote from EBAY like LAST WEEK and I was reading and some people said you need a SCAN TOOL or the DEALER has to program it for you, NOT TRUE, You can do it YOURSELF!!! I recieved my remote in the mail, EASY INSTRUCTIONS, followed them, and MY REMOTE is WORKING PERFECTLY!! SO if anyone needs the instructions on how to program, I will GLADLY give them to you!!
It takes literally SECONDS to program, WHY ON EARTH would ANYBODY pay a dealer to do that?? ITs a RIP OFF if you DO! YOUR CHOICE.
Thanks
Old 01-23-2006, 03:02 PM
tman's Avatar
tman tman is offline
Pimpin' ain't easy
Send a message via AIM to tman
Re: 1999-2000 Buick Regal Keyless Entry Remote
Go ahead and post what you've got and I'll make a sticky of the thread!
Old 01-23-2006, 04:36 PM
BNaylor's Avatar
BNaylor BNaylor is offline
The sticky from Flatrater on programming remotes works fine a '99 Regal LS.
Not sure about a 2000. Post the procedure and I'll see if it works on my '01 Regal GS. If it works and free, I'm happy. Thanks for the info.
Timeslip 08/12/06
AF Community Guidelines
Old 02-13-2006, 08:31 AM
Re: 1999-2000 Buick Regal Keyless Entry Remote (INSTRUCTIONS!!)
THESE INSTRUCTIONS ARE FOR:
  1. 97 GRAND PRIX
  2. 97-00 REGAL
  3. 97-00 CENTURY
  4. 2000-MALIBU
  1. CLOSE VEHICLE DOORS
  2. INSERT KEY INTO IGNITION, TURN TO ON
  3. TURN TO OFF AND REMOVE KEY
  4. PRESS AND HOLD THE DRIVERS SIDE DOOR LOCK SWITCH IN THE UNLOCK POSITION
  5. INSERT KEY INTO IGNITION AND REMOVE
  6. INSERT KEY INTO IGNITION AND REMOVE
  7. INSERT KEY INTO IGNITION
  8. RELEASE DOOR LOCK SWITCH (VEHICLE WILL SOUND THREE BEEPS TO VERIFY PROGRAM MODE)
  9. PRESS THE LOCK AND UNLOCK BUTTONS TOGETHER ON THE KEYLESS ENTRY TRANSMITTER, HOLD UNTILL THE VEHICLE BEEPS TWICE (ABOUT 15 SECONDS)
  10. REPEAT STEP 9 WITH OTHER TRANSMITTERS
  11. REMOVE KEY FROM IGNITION
THE STEPS WORKED FOR MY 2000 BUICK REGAL WITH NO PROBLEM! NO SCANNER NEEDED!!
WHY PAY SOMEONE OR A DEALER FOR A COUPLE SECONDS OF WORK!?!?
ANY QUESTIONS PLEASE CONTACT ME @ [email protected] THX!!
Old 02-13-2006, 11:52 AM
Onblsht's Avatar
Onblsht Onblsht is offline
Authorized Vendor
Those instructions work for every car using the ABO0204T / 10246215 remotes, which are usually 97-00 models.
Replacement keyless entry remotes available here - up to 90% off -
All makes/models from Acura-Volvo, 1988-present -
http://www.OriginalKeyless.com
Old 02-21-2006, 08:54 PM
stockgp stockgp is offline
Send a message via Yahoo to stockgp
just fyi, you should be able to program every gm car's keyless entry remotes up to 2002. after that a dealer has to do it or someon with a tec2
Old 02-22-2006, 10:01 PM
katana1981 katana1981 is offline
Send a message via MSN to katana1981
its exactly the same instruction that I have for my buick regal LS 2002
Old 02-24-2006, 10:12 PM
Onblsht's Avatar
Authorized Vendor
There are many GM cars with remotes that can be programmed by their owners after 2002.
