Old 01-09-2006, 08:55 PM
blazertazer blazertazer is offline
85 s10 blazer 2.8 to small block engine
I was wondering if a 305,327,or a 350 would fit in my 1985 s10 blazer 4x4 2.8 liter? i just need and gotta have more power! if a small block v8 is not possible does anyone have any ideas?
Old 01-09-2006, 10:25 PM
OverBoardProject OverBoardProject is offline
Banned
Re: 85 s10 blazer 2.8 to small block engine
Yup, It'll fit!
You'll need the motor and transmission, and odly enough you already have the right motor mounts. Although you'll need a custom set bolted to the motor.
A google search should show you a few and some of the members have done the swap. So if your handy you should have lots of info.
And Welcome to Automotive Forums
Old 01-10-2006, 12:48 AM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
welcome, it fits, keeping 4x4 is the challenge (what ive heard, never done it to a 4x b4), you need, moter, computer, block mounts, wiring, i reccomend an aluminum radiator and e fan (wont get the clutch fan in there anyways) transmission (yes, you have a 700r4 on your 2.8 but it is a v6 bell housing, dont work, been there with the firebird), a couple big pry bars, and some beer... so you will use the bars (seriously get your ass in to it) depending on your location (salt belt or not) a torch for some of the bolts, and a good weekend to not be interupted, last one i didn't take us to long (12 hours or so i beleve) but it was the third one we had done, the first one is a pain in the ass learning experence, and a heads up, at the bottum of the firwall there is a pinch weld, beat the hell out of it, it gets in the way every damn time
Old 01-10-2006, 12:50 AM
o, btw, a 350 will fit just as easy as a 305 or 400, all small blocks have the same dimentions on the outside, and all small block parts are interchangeable, a good 350 block some nice 305 heads and flat tops on a sequental v8 and you will have more power then you know what to do with
Old 01-10-2006, 01:09 AM
Banned
85 is still carburated so you won't really need any electronics blazertazer. Your a lucky man there it should be a little easier than what DM has to do with his conversion.
Just find the best motor possible and switch to a carburated manifold.
It's a good idea to stay with a non electronic transmission. I would look under a 85 Full sized pickup for that
Old 01-10-2006, 08:52 AM
Floyd_ODB Floyd_ODB is offline
Buy the JTR manual in this article> http://www.hotrod.com/techarticles/72738/
I have 400SBC in mine, check pics here> http://www.automotiveforums.com/vbul...d.php?t=498078
as we should know the 400 is prone to overheating because coolant does not flow between the cylinders(siamese cylinders)
I use the copper corvette radiator and has never even wanted to overheat(90deg day in stop and go traffic)
