Old 01-03-2006, 05:35 PM
Skyline_BNR34's Avatar
Skyline_BNR34 Skyline_BNR34 is offline
Registered User
AWD v. MR
O I have this irretating guy who keeps saying MR cars have better handling than an AWD car. Which is correct, I say that AWD has better handling because all wheels are spinning and it dosen't break loose and loose traction, and MR will break loose sometimes and is easier to spin out.
I just want to prove this guy wrong because he thinks he knows everything about cars.
Old 01-03-2006, 06:01 PM
Black Lotus's Avatar
Black Lotus Black Lotus is offline
Re: AWD v. MR
You're not gonna prove him wrong with THAT argument. The only person that couldn't loose control of an AWD car and spin it into a tree if that's what he/she wanted to do, is a person that couldn't reach the gas pedal in the first place (a toddler or an infant).
Also, remember that "handling" is utterly independant from "performance".
So, my 3 opinions.
---The best handling platform for cry babies and girly men (like Elton John and his new bride) is FWD.
---The best handling car for intermmediate levels of driver is AWD.
---The best handling and the most satisfying car to drive for advanced skill drivers is mid-engined rear drive.
Again, my opinion only. And I won't bother to elaborate because this thread will turn into a total snake pit anyway.
Old 01-03-2006, 07:51 PM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
Re: AWD v. MR
Well, sexuality-bashing aside; it depends on the type of handling and performance you seek. If you're just coasting and yanking the wheel, the MR has the lower moment of inertia. So in addition to being more balanced in the weight catagory, there is less weight at the extremes of the car. Picture it like putting a case of beer in the front of your shopping cart and trying to turn quickly. Now move it to the center of the cart and its much easier. Same weight, better placement.
AWD has its advantage in that both axles pull making more neutral over/under steer characteristics due mostly to traction assistance, but it has almost nothing to do with lateral grip or moment of inertia.
Its darn near impossible to answer the debate with current parameters. We're debating which handles better; this car with certain weight qualities, or that one with certain traction qualities. Its like asking; which is better, Orange Juice or Poodles?
Dragging people kicking and screaming into the enlightenment.
Old 01-04-2006, 08:04 AM
Reed Reed is offline
Send a message via AIM to Reed
Re: AWD v. MR
i just want to throw in my vote for MR. Just so when this does turn into a snake pit i'll be toward the top.
Cars are like music.
If it ain't fast it ain't shit.
Old 01-04-2006, 12:52 PM
ac427cpe's Avatar
ac427cpe ac427cpe is offline
Miata is always the answe
Send a message via AIM to ac427cpe
Re: AWD v. MR
Orange juice.
better in what way? for racing? rally or F1?
hello, i am Dan
No more project cars. I wonder how long that will last...
Old 01-04-2006, 01:19 PM
Registered User
Re: AWD v. MR
Ok so it is all dependent on more variabes than just what we were talking about, so basically both is just as good and basically they handle the same.
Old 01-04-2006, 01:40 PM
curtis73's Avatar
Re: AWD v. MR
How about an MR with AWD? Now that would be wicked. Diablo VT had that... any others?
Old 01-04-2006, 02:47 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Re: Re: AWD v. MR
Well its replacements the Murcialago and what ever the other one are both have AWD.
The Buggatti EB110 also had AWD.
Old 01-04-2006, 02:48 PM
Moppie's Avatar
Master Connector
Re: Re: AWD v. MR
We had better swap cars then.....
Old 01-04-2006, 05:06 PM
Altimas Altimas is offline
Re: AWD v. MR
MR>*
AWD helps you get the power down but seeing as most AWD setups are front engined, you get similar weight distros to FWD cars so you get arund 60% weight in the front generally so it doesn't handle any better when not accerating (worse than FWD since it adds weight) but it helps you get out of the corner.
Given alot of AWD setups are FWD untill the front wheels slip(vicous coupling) and then use a 50:50 spit (based on FWD) I really wouldn't touch those with a 10 foot pole since they have power on understeer.
But with cars like the wrx with adjustable splits, it's better since you can make them behave like a RWD car but still fat slicks AWD isn't needed for tarmac racing.
Basically AWD doesn't help handling a bit, it just helps you get the power down while MR and argubabally RR help handling and getting the grip down.
The problem with MR and RR (more drastic) is lift off oversteer and with RR (porche's) is power on understeer since there is so little weight up front.
RR is excellent for braking though.
Old 01-04-2006, 07:10 PM
Re: Re: Re: AWD v. MR
Oooh, you goof!
You're just being a big silly!
(tee hee)
