Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 01-03-2006, 04:30 PM
spamman23 spamman23 is offline
no heat
MY 97 Cron Vic has no heat. We have narrowed it down to the acutator blend door motor. I have been quoted 700 bucks to get this replaced. The dealer said that they would have to rip out the dash and stearing column. We are thinking about trying to force it to the hot position. We were wondering if i take out the radio and drill out the plastic wall behind it will i be able to get access to the motor? Any ideas?
Old 01-03-2006, 05:36 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: no heat
You can access the motor by removing the glove box. It is located to the top left of the glove box hole. It is tight, but it can be done. Just make sure you remove all the bolts that hold it to the heater/ac plenum.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 01-03-2006, 08:57 PM
is there some way i can use a screwdriver to push it into the hot position?
Old 01-04-2006, 10:48 AM
way2old's Avatar
TOKEN HILLBILLY
Re: no heat
I don't think so unless you remove the servomotor. Yhere is not a place to access the door.
Old 01-11-2006, 11:35 PM
zaheer123 zaheer123 is offline
Re: no heat
may be your heater core is blocked and hot air is not coming in.
