Old 01-02-2006, 03:45 PM
Tplayer Tplayer is offline
Air Blower /AC/Heater
Hello,
Recently when I went to turn on my AC the air flow was comming out of both the vent and down below where the heat usually comes from.
I made sure I had the dial set to the correct position. Also when I set the dial to Max, there doesn't seem to be any difference in out put pressure as there was before.
Does anybody know how the airlines run. If I know that I can check to see if anything is pinched.
I recently changed my battery but I didn't see any airline running around the area.
I'm sure I'm going to find a pinched air line but I just don't know where to look.
Please help.
Old 01-02-2006, 04:10 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Air Blower /AC/Heater
You just about answered your own question. The accessory vacuum line for HVAC control runs right by the battery under the engine compartment fuse box. It originates at the intake manifold for GT/SE and supercharger for GTP and runs in a round about way by the battery and into that main wiring harness that feeds into the firewall. It is made of plastic and can get damaged very easily especially when removing and replacing the battery. If you look very carefully you will see it. Good luck!
Timeslip 08/12/06
AF Community Guidelines
Old 01-02-2006, 06:41 PM
Well you're right on. I removed the window washer fluid container and I saw two little lines that had come detached from one another. It seems they were spliced together.
Once I re attatched them everything worked good as new.
Thanks.
Tplayer
Old 01-03-2006, 07:40 AM
BNaylor's Avatar
Thanks.
Tplayer
Glad you got it resolved and you are welcome. Thanks for the feedback.
Timeslip 08/12/06
