Old 01-01-2006, 06:42 PM
Torsen Torsen is offline
Question Diffs and irs and stuff
I'm not sure where i should be posting this but the more i ask the more i'll know, maybe. I'm thinking about putting a Mustang 4.6 DOHC(new with six speed and axle from frp into a (wait for it) 1986 Ford Capri 2 door fastback.
Well, I want to convert it to irs along the way. What parts will work with the Mustang axle assembly?
another question - Are Torsen diffs any good(ie better than clutch type lsd) in a rwd.
I know my username would suggest i know all about them but ive only had them in an audi s4 quattro, which went to the recycling plant following a recent misadventure.
By the way happy xmas/new year an all that stuff.
Old 01-01-2006, 07:33 PM
01L2Cobra's Avatar
01L2Cobra 01L2Cobra is offline
Re: Diffs and irs and stuff
An IRS in a Capri can be done but its a lot of work. I would contact this place. They have installed a 99+ IRS in to a SVO so they may be able to tell you what all will be required.
http://www.motion-dynamics.net/produ...3/default.html
The ///M stands for Motorsports
Old 01-02-2006, 09:42 AM
Thanks Cobra. I'll check it out.
Old 01-03-2006, 09:32 AM
SVTcobra306's Avatar
SVTcobra306 SVTcobra306 is offline
Theoretically it should be fairly simple on the IRS, since they designed it around the same mounting points on the same chassis.... However I believe they re-arranged the setup just slightly for a wider rear width in '99, so you may run into some troubles there....
1994 SVT Cobra. 306, Ported GT-40X's, Crane 2031, NX Wet Kit (100 shot for now),TKO 500, TwEECer R/T, and all the bolt-ons.....
http://www.cardomain.com/id/mccobra94
1995 F-150 SC/4X4 351W/E4OD, K&N, Custom Exhaust w/Flowmaster.
Freedom Isn't Free.
Old 01-03-2006, 09:58 AM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
If you do a websearch there is someone's personal site who did this nad has a good step by step with pictures. It's actually quite easy and only a few tricky points cause they are sitting on the same basic chassis/mounting points. Also remeber your gonna need a new cat-back to clear the IRS.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
