Go Back   Automotive Forums Car Chat > Honda > Locations (USA, Canada, Asia, etc...) > Asia/Pacific
Asia/Pacific Members from Japan, Philippines, Korea, Malaysia, Australia, NZ, etc...
Old 06-07-2002, 10:31 PM
TOYVTi's Avatar
TOYVTi TOYVTi is offline
Send a message via ICQ to TOYVTi
Ef9 with b18C??
So can that be done? I heard that they just bolt in to the ef9 Civic Sir? Evil Elmo, wat do u say? Also elmo, did ur ek have to get a new computer, or did the loom just plug in? WIth the b18c in to the ef9, is there anyother things that has to be done?
Cheers
TOYVTI
HI YAH VTEC!
Forma JDM Integra SiR =)
Forma JDM Mitsi Galant VR-4 98' Spec
Old 06-07-2002, 10:43 PM
Spunkymonkey's Avatar
Spunkymonkey Spunkymonkey is offline
Wait til Pete gets back to reply...I think they bolt straight into EK, but EF...cable and hydraulic clutch differences...
harder I think.
There's a chick driving that thing
www.performanceforums.com
Old 06-08-2002, 12:22 AM
Setanta's Avatar
Setanta Setanta is offline
Send a message via ICQ to Setanta Send a message via AIM to Setanta Send a message via Yahoo to Setanta
I'm back - what a day
Ok - mounts etc it will all bolt up, except the tranny front mount apparently. Engine is a little bit taller, but will *just* fit. A hydro clutch setup needs to be converted and apparently, there is a good chance the driveshafts may be wrong (unconfirmed). Computer would have to be changed is my guess as the 1st gen B16As ran different setups to the 2nd gen.
My guess is that 95% of the conversion is simple as the EF8/9 engine bay tends to resemble an EG or EK in engine mounting positions.
In an ED (Aussie spec 4th Gen it's a lot harder of course as it's based around the D series engines, not the Bs).
I wouldn't do the conversion though, although I admit I have thought about it
Sigh - I've just sold myself on a complete new exhaust system - extractors - flex pipe, high-flow cat, 2 1/4 inch mandrel bent system, high flow muffler and.... SiR tips
Cost is just under a grand for the lot fitted. Going to window shop a bit more, but I'm pretty much sold on it.
Of note, the SiR exhaust is already 2 1/4 inches in diameter, but press bent not mandrel.
Heheh - should have seen the guy's face when I said I wanted the factory heat shield on the headers and the SiR tailpipe - fortunately, the tailpipe will flow up to 2 1/2 so that's cool.
'99 PY DC2R
'85 BBS BMW E30
RIP '90 JDM EF9 Civic SiR
Old 06-08-2002, 01:45 AM
BurgerBoy's Avatar
BurgerBoy BurgerBoy is offline
I like stuff!
Send a message via ICQ to BurgerBoy Send a message via AIM to BurgerBoy Send a message via MSN to BurgerBoy
Re: Ef9 with b18C??
Cheers
TOYVTi, go ask Cement on the nzhondas message board. he had a B18C in his EF9 civic
http://www.dogbite.co.nz
MSN: [email protected]
AIM: pureJDMteg
Old 06-08-2002, 03:19 AM
evil_elmo's Avatar
evil_elmo evil_elmo is offline
Send a message via Yahoo to evil_elmo
my b18c bolted straight into my Ek, i re-wired all the computer, so i'm running a standard b18c one, it wasn't too hard just need abit of time and the right parts
still thinking of what car to get Toy
Original PureHonda Member
JDM
hybrid B18c EK sedan & EG Hatchback SiR
Click here for Pictures
Old 06-09-2002, 01:49 AM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Well if you use the Y1 gearbox that the EF9 comes with then it really is a stright bolt in swap.
Just make sure you also get a pre 95 VTiR teg ECU as well. Bolt and plug the engine in, then plug in the ECU.
and away you go........................................
edit, I would also use the intake manifold of the B16a as well. It will fit better in the tighter engine bay, and they flow better.
Old 06-09-2002, 03:54 AM
evil_elmo's Avatar
intake manifold from a b16a, b16b, b18c R doesn't fit the B18c the only one that fits is the Skunk 2 one
and yip its going to be a bitch if you have to changed from OBD1 to OBD2
JDM
Old 06-09-2002, 07:04 AM
Moppie's Avatar
Master Connector
Oh yeah. I forget that he B18c has a differnt intake ports. Oh well.
As for the OBD the EF9 is already mostly OBD1 anyway. It has the two O2 sensors and the right dizzy. So it really is just a matter of plugging in an OBD1 ECU from a VTiR. You dont have to, but the B18c and the B16a have differnt VTEC engagement points, and there will be slight differnces in the fuel and ignition curves.
What Edelbrock Intake should i go with? inforcer958 General Discussion 4 02-14-2011 07:58 AM
JDM used EF9 rear hatch with spoiler gspeed '88 - '91 Civic | CRX | Wagon | Shuttlee 1 02-13-2004 11:26 AM
b16a with 95 jdm gsr b18c tranny with lsd YZ125rider21 '88 - '91 Civic | CRX | Wagon | Shuttlee 5 12-05-2003 05:40 PM
EF9 with hydro trany? wikedcrx '88 - '91 Civic | CRX | Wagon | Shuttlee 4 04-06-2003 10:45 AM
Still need help with EF9 lighting wiring ossirisus_ef9 '88 - '91 Civic | CRX | Wagon | Shuttlee 1 05-09-2002 03:48 AM
