Old 12-23-2005, 06:32 AM
935k3's Avatar
935k3 935k3 is offline
Iwata Eclipse users. A few questions.
I just bought an Iwata Eclipse and just want opinions on how it worked for you. Also would appreciate any tips on use ,maintennance,dis-assembly and cleaning.
Thanks to all in advance.
Old 12-23-2005, 08:50 AM
SteveK2003 SteveK2003 is offline
Send a message via AIM to SteveK2003 Send a message via Yahoo to SteveK2003
Re: Iwata Eclipse users. A few questions.
I would also like to hear about this as well.
Old 12-23-2005, 09:56 AM
speedphreak speedphreak is offline
Its very very very simple. Also it comes with instructions..lol...not to be an ass or anything, sorry. But seriously, its a very universal airbrush. 1st one I purchased when starting. Dis-assembly is simply just unscrewing and screwing back together. The needle is difficult to re-install, just be careful not to bend it and take your time with it. That is all.
-Chris
Old 12-23-2005, 11:04 AM
Ferrari TR's Avatar
Ferrari TR Ferrari TR is offline
Not A Hoarder!
There are several articles on the iwata site, which I found helpful.
On my Revolution the only thing new/different was the trigger tension adjustment, which was not covered in the supplied instructions.
SCCA 7, The lost Z
Old 12-23-2005, 01:16 PM
WasteGas's Avatar
WasteGas WasteGas is offline
I usually fill a second bottle with either alcohol, windex or laquer thinner depending on the paint job and shoot it through the brush.
I don't take it apart often. When I do, it's pretty clean, that's why I just shoot solution through it instead. I don't want to bend something by accident from taking it apart all the time.
Old 12-23-2005, 11:21 PM
p9o1r1sche's Avatar
p9o1r1sche p9o1r1sche is offline
Registered User
I love mine. Its much better than the Model Master I used for years. The droplet size is much smaller and more consistent. Some people may like to have a higher paint flow, though. The only issue I had was a small metal chip from the airbrush manufacturing process got stuck in the air valve seat and it wouldnt seal off the air. It was easily fixed because the airbrush can be totally disassembled. The only maintenance I have needed to do was clean the needle. Just unscrew the back of the handle, unscrew the chuck holding the needle and pull the needle out. Be very careful that you dont bend it. I wipe the needle off with a rag and lacquer thinner.
