Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 06-07-2002, 11:01 AM
kris's Avatar
kris kris is offline
Off playing with fire.
Cleaning a turbo.
I just picked up a turbo off a Starion. While I am waiting for some other parts to get in, I wanted to clean this turbo up some. It seems to have alot of carbon buildup, dirt, etc. on it. When I pull it apart to inspect everything, is it okay to clean everything off? If it's okay to do that, is there anything I should not do to prevent any types of damage?
Thanks
Old 06-07-2002, 02:10 PM
Rgacke's Avatar
Rgacke Rgacke is offline
definetly don't let any dirt get inside. My friend caped his up and used a dremel to lightly "sand" the outter housing, looks like new. As for the inside, if it ain't broke, don't fix it. If its just the housings its not a big deal, you can remove and clean 'em but store the cartridge in a zip-lock bag or something, don't get crud on/in it. After you get the turbo hooked up run the drain line to a bucket and just crank over the engine so dust/dirt will come out and you can tell if theres any obstructions in the turbo. hope this helps
"shut the door Joshua, and let death pass by..."
Old 06-07-2002, 07:06 PM
kris's Avatar
Good idea on letting it just pump through. I just pulled the housing off and cleaned it up with the dremel. Now it looks good.
Old 06-25-2002, 01:44 AM
jdblack1 jdblack1 is offline
polish and clean was just time consuming/about 3hrs
Old 06-25-2002, 06:20 AM
kris's Avatar
Nice, where did you get your adapter plate, or did you make it yourself?
Old 06-25-2002, 01:20 PM
made it myself
Old 06-30-2002, 11:34 PM
Tominos Tominos is offline
what tools machines do you need to make the adapter plate yourself? also where can you get the metal for the adapter plate, i don't know since the metal is pretty thick(1/2")
Want to turbo a 96 Eclipse 2.0 non turbo donidavis Engine, Transmission and Drivetrain 7 12-02-2010 08:23 AM
Exterior Cleaning ? - Acura TL ShineForMe General Discussion 2 04-19-2010 04:35 PM
Cleaning O2 Sensors CCMphysician Engineering/ Technical 4 01-15-2010 07:47 AM
brake light and dashboard cleaning sailor86 Engineering/ Technical 4 12-29-2009 07:40 AM
89 probe gt turbo TURBO LEAKAGE sweetbiker Probe 0 03-08-2009 04:25 PM
