Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 12-19-2005, 01:04 PM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
Wheel interchange
I have a 1995 Buick Roadmaster, and I know they are similar to the Caprices and Impala SS of the same genre. I was wondering if the wheels off of these cars are interchangeable? I want to get a spare set for my summer tires, and a friend who used to have a Hollander interchange manual no longer is in possession of it, so I can't readily look it up to see. Any help would be appreciated.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
Old 12-19-2005, 02:26 PM
PeteA216's Avatar
PeteA216 PeteA216 is offline
Send a message via AIM to PeteA216
Re: Wheel interchange
I'm almost positive they'd fit as long as they're not the alloy rims. The alloy rims may sometimes not fit because of the larger hub in the center front wheels depending upon where you get them. Steel rims from a Caprice of almost any year should fit right on. Last week I had to let a buddy of mine borrow my spare tire (84 Caprice) for his 93 Pontiac Trans Am, and it fit right on without any problems. So it if my rims fit on a newer sports car, then I dont see any reason why they wouldn't fit on another GM sedan.
Old 12-19-2005, 03:01 PM
1986Z28's Avatar
1986Z28 1986Z28 is offline
Has a Camaro
Send a message via MSN to 1986Z28
yeah there both 5 on 5, not sure about alloys, but the steels wheels will fit
Formerly Blownalcoholboy
1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi)
Best ET 1/4: 8.35 @ 170mph (275 drag radial)
Best ET 1/8: 5.44 @ 132mph (275 drag radial)
Best 60': 1.31 on the back tires (275 drag radial)
AF User Rules/Guidelines
http://www.automotiveforums.com/vbul...uidelines.html
Old 12-19-2005, 08:22 PM
CD Smalley CD Smalley is offline
As long as you stick in the 91-96 range for donor wheels you will be fine.
If you get something older than that, then the must come from a wagon or 9C1.
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Recently updated: http://forums.b-body.org
Old 12-19-2005, 09:31 PM
The reason why I first posted the question was that a friend of mine purchased a '96 Roadmaster at the same time I bought my '95 and he told me he was taking a good pair of tires off his '92 Caprice sedan wheels so he could use them on his Roadmaster as the Caprice rims wouldn't fit his Roadmaster. (He traded the Caprice in for the Roadmaster.) I thought that the wheels would fit at least from '91 to '96, and maybe he did something wrong. I'm going to look into a set from a Caprice and see if they will fit my car. Thanks for the replies.
Old 12-19-2005, 10:41 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
The 9C1s and wagons have a 5x5 bolt pattern. Standard civvie sedans have a 4.75x5 bolt pattern.
Old 12-20-2005, 12:46 AM
beat88ls's Avatar
beat88ls beat88ls is offline
i know that 89 cadillac rims wont fit my 83 caprice the bolt pattern wont match up
1997 Jeep Grand Cherokee Laredo 4.0L
2004 Jeep Grand Cherokee Laredo 4.0L
1983 Caprice Classic 5.0L
Old 12-20-2005, 05:05 AM
Re: Re: Wheel interchange
This is only true for PRE-91 cars. After that they are all 5x5.
97ventureowner - I'd guess that he never tried them. They should fit w/o problems. I've seen dozens of people take ImpSS wheels and use them on wagons of all makes.
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Old 12-21-2005, 02:17 PM
1986Z28's Avatar
Has a Camaro
yes aas cd smalley said only pre 91's had a 5 x 4 3/4 bolt patterns on the civvies all 91-96 had 5x5 as mine is a civvie and it has 5x5
