Old 06-06-2002, 04:17 PM
endlesskev86's Avatar
endlesskev86 endlesskev86 is offline
Send a message via ICQ to endlesskev86
ENdless Altezza
man i can't wait to get the Endless Altezza Kit made by fujimi!!!
as so as i finish my integra Type-R (new ver.) i will start working on it!
I got one Q..... my friend's HKS Kansai Altezza's car body is gray...... do u think that the paint will cover the gray part if i sprayed blue paint on it?
something shitty happend to me along time ago when i was workin on my second model. The model was a Civic si hatchback. the car body was gray and i wanted to make into a Civic Spoon. So i tried spraying yellow paint on the body....... well it did not work really well cause i ended up using two cans of PAINT!!! do u think if i use primer this time it will work out?
AF OG Dori crew (member #5)
Altezzas: It only looks good if you have the FULL car, not just the LIGHTS!! grinyes:
Old 06-06-2002, 04:29 PM
siege35 siege35 is offline
Send a message via AIM to siege35
Regardless, you'll want to lay down 2 or 3 primer coats before spraying any color. For a dark color like blue, grey primer is fine...but if you're ever going to spray a light color like yellow again, white primer will be a better choice and you'll be able to make it with less than a can probably
Old 06-06-2002, 04:31 PM
another Q... wat is the difference between gray primer and white primer?
Old 06-06-2002, 04:34 PM
daggerlee's Avatar
The color
Dan
Old 06-06-2002, 04:38 PM
well yeah i know the diff is the colour,.......
how do i know when to use which colour?
Old 06-06-2002, 04:39 PM
do i white primer for lighter colour and gray primer for darker colour
Old 06-06-2002, 05:16 PM
MX100's Avatar
MX100 MX100 is offline
Send a message via ICQ to MX100
u think u r really gonna get it.~!?!? lol~
obviously.......bak chi jai~~ haha~ want me to strip the paint of the altezza and spray it blue for u to c~!?~!!?!~?
and yes guys it was a pretty screwed up model =) i'll take a camera with me and go to his house and let u gusy c the pic~!! hah~ =)
Current Project: Tamiya Nissan Skyline R34- 70%
Next Project: Honda S2000 type V, Subaru Impreza WRX STi, Modulo DC5, Veilside MRS
http://community.webshots.com/user/a_bathing_ape
Go to that site to view images of my models and other car pics..enjoy!
Old 06-06-2002, 06:22 PM
primera man's Avatar
"P-Man"
Easy answer about the primmer....just use white on everything...thats all i have every used and it works just fine.
View All My Models Here.
Old 06-06-2002, 07:14 PM
pkw1's Avatar
pkw1 pkw1 is offline
hey dude,
if you don't mind posting some pics of the DC5, I'm looking in getting one
All projects stalled...
Need to settle in on my new job, and don't have time to built models just yet.
Old 06-06-2002, 08:18 PM
hirofkd's Avatar
hirofkd hirofkd is offline
Best way to learn is to try it for yourself, because it's kinda hard to explain about color in words. Basically, you can control the final color, by changing the base color, for example...
Let's say, you have a can of white primer, gray primer, yellow, pink and red.
Spraying red on gray primer would result in dark bloody red, such as Alfa Romeo. Using white primer and yellow as a base color, you get very bright orangish red. Using white primer and pink, you get vivid red.
Now, yellow is very translucent, and it's easily affected by the base color underneath it, so if you paint the body with white primer, the final color would be bright, and I think that's what you originally wanted.
These days, white primer is opaque enough to cover the color of plastic, but if not, try using tan as a base color for yellow.
I'm not sure I'm explaining this right, but basically you have a choice of primer color, base color and body color, and the result depends on a combination of those three.
Hiroaki Fukuda
Old 06-07-2002, 11:15 AM
well thnx guys for ure advices....
special thnx to benny for his non-stop crap ass advice.....
if u want to get a camera in my house u would have to go pass my metal detectors!
altezza rs 200 z-edition superman1 IS200/IS300/IS350/Altezza 0 01-26-2010 01:23 AM
The endless catback Exhaust Question pkjie108 Integra 3 01-22-2004 05:41 PM
endless negative camber... xlosinghopex Tires and Wheels 8 02-24-2003 08:06 PM
Decals for JGTC Arta NSX/Endless Skyline? sausage Car Modeling 2 10-27-2002 01:10 AM
endless brakes dubss '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 8 02-05-2002 11:45 AM
