Old 10-11-2003, 05:10 AM
swest_jefe swest_jefe is offline
Unhappy Misfires Under boost
Hey, Im having a serious problem. I have a 90 GSX. It runs fine until the boost starts to kick in. Then it misfires and sputters like crazy, it actually loses power under boost. Plugs are fine, injectors are fine, seems to be a timing problem or something. Could it be a bad ECU, or maybe the MAS? Anyone had any similar experience?
Old 10-11-2003, 05:13 AM
By the way
Running 12 lbs on a 16g at 5000 ft, everything else stock.
Old 10-11-2003, 06:43 AM
FourG63 97GST FourG63 97GST is offline
Send a message via AIM to FourG63 97GST
yea that happened to me when i put new 8mm wires in. it like misfired under boost only.when i put the stock wires, my car ran fine.
i put the same 8mm on another GST and it ran fine, even under boost
so the conclusion is that I had bad spark plugs, you may want to check those
-Agim
Old 10-12-2003, 05:08 AM
kjewer1 kjewer1 is offline
AF - Advisor
This defintely sounds like an ignition problem, though there is the chance it could be a bad boost leak (see the vfaq for how to build the tester and check it out). Try to use only NGK plugs, like the stock ones, gapped to 28 to 30. BE wary of what wire you decide to run. They almost all give DSMs problems. The ones that work 99.9% of the time right out of the box are NGKs. Some people swear by Magnecores, but I've had 3 sets go bad on me. I still run stock wires, a couple years old, to 11 second passes and 400 whp on pump. Works for me.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 10-13-2003, 04:10 PM
turboawdgsx turboawdgsx is offline
Re: Misfires Under boost
I vote for boost leak, I tested so many things, only to find out the turbo inlet was incorrectly installed and had a 1/4" gap around the inlet pipe. New piece put on, all boost problems were fixed.
Rob
"Got car lenghts?" or "You can turbo anything but can't make stupid people smart, something wrong with this picture?"
Old 10-13-2003, 04:23 PM
Thx, Ill try changing the plugs and wires first, if not that then Ill check for the leak. Hopefully I can figure it out.
Old 10-13-2003, 08:37 PM
Talon007's Avatar
Talon007 Talon007 is offline
Send a message via MSN to Talon007
Check for a boost leak first then change plugs & wires.
Chris Clark
www.Talon007.com
1990 Eagle Talon TSi AWD - In Progress
1993 Eagle Talon TSi AWD - Parts Car
1990 Eagle Talon ESi - Sold
1-800-VFAQ - Bookmark it, read it, use it
