Old 06-06-2002, 09:19 AM
CivSiGuy's Avatar
CivSiGuy CivSiGuy is offline
Banned
Send a message via AIM to CivSiGuy
Give me and order to buy in here
alright here's thes stuff... give me an order when to buy it in and why.
Skunk2 IM
AEM fuel rail
AEM FPR
CTR/ITR cams
Apexi VAFC
Prelude injectors
Old 06-06-2002, 09:47 AM
sweetcarz.com sweetcarz.com is offline
Banned
Send a message via AIM to sweetcarz.com
Re: Give me and order to buy in here
Skunk2 IM
AEM fuel rail
AEM FPR
CTR/ITR cams
Apexi VAFC
Prelude injectors
here is what I would do.
Here are a few things to consider. Keep in mind some things such as the cams and VAFC are going to have to be dyno tuned. Try to get those things done first. I would leave the VAFC to last though becuase you want it reacting at peak performance for your setup, then you change your setup and you if you want peak performance you should go dyno tune the AFC again. So the VAFC I would buy last.
Old 06-06-2002, 02:10 PM
drift's Avatar
drift drift is offline
Send a message via AIM to drift
Skunk2 IM
AEM fuel rail
AEM FPR
CTR/ITR cams
Apexi VAFC
Prelude injectors
well, there's some redundancy and just plain useless parts in your setup. if you're going for looks, get everything. if you're going for performance, forget the injectors, rail, and fpr as they arent needed for a naturally aspirated buildup. these all flow more fuel than any naturally aspirated honda motor needs.
besides, the VAFC will tune fuel, and you do not need more fuel than the VAFC can tune in... so the fpr is a definite waste of money.
here would be my list, in order
1. Cams and adjustable sprockets. you'll gain enough for your buttdyno to feel with this mod alone. since you're installing the cams, it will be easy to just drop in the sprockets at the same time, so get them both at the same time.
2. Intake manifold. you probably wont feel shit from this mod since it's about the same design as the B16A manifold. i'd personally get the stock manifold ported and polished, and portmatch an overbored throttlebody with it. that would be your biggest gain.
3. VTEC controller. then get the cams and fuel tuned on the dyno. now if you only have $300 burning a hole in your pocket, get the VAFC now as it wont make much difference when you get this. you can also use it to drop your VTEC x-over on a stock motor and gain a few midrange ponies.
(eBook) Buying New and Used Car Tips schumi_reloaded Car Buying Q&A 2 06-05-2009 12:18 PM
New buy here Giampiero GTRA / GTWS / GTS 4 03-15-2008 12:43 AM
Anything worth buying here? pirata12 Car Modeling 22 09-13-2006 10:11 AM
CHEAP 17 inch BBS rims buy here for 500 or pay 1000 from volvo turboneticssti C70 2 02-09-2005 08:58 AM
