Old 06-06-2002, 07:28 AM
BlkSprk's Avatar
BlkSprk BlkSprk is offline
2 Questions about my 91 Eclipse
OK, i have two questions that i havent been able to find answers too.
1. Can i put the front end of a 92 ecplise on my 91 with minimal modifications, so i can use a wider range of body kits?
2. I am planning on turning my car to a drag car, it is FWD, should a)I scrap it and buy an AWD b)Have an AWD chassi installed (assuming this is possible) or c)Use as is and not worry?
I apriciate any feed back i can get. thank you
-BlkSprk
Old 06-13-2002, 09:03 PM
ECTurboGSX ECTurboGSX is offline
Send a message via AIM to ECTurboGSX
Well, if I were you and in your predicament, I would buy a 92 AWD. Depending on how fast you want to run, would determine whether you need awd or stay with fwd. When you get into faster DSMs, the AWD will generally run atleast a second faster than the FWD with the same mods.
Eric
1990 Mitsu Eclipse GSX
13.4 @ 102.9
Big 16G @ 19 psi
Old 06-14-2002, 01:33 PM
BlkSprk's Avatar
but dosnt the 92 engine run about 20 hp lower than the 91? if so how hard is an engine swap?
Old 06-14-2002, 07:36 PM
Not at all. The turbo eclipses with the manual trannies had 195 hp from 89 to 94 and then 210 from 95 to 99. The 89 to 94 autos had 190 hp. The 89 to 91 had the biggest rods, while the 92 to 94 had the 4 bolt rear end (stronger) and the 95-99 had the best pistons, while the 92 to 99 AWDs had the best brakes. I would say look around for a 92 model. In order to use a 92 front end, you have to get 92 head lights, fenders, hood, and front end, plus manufacture new mounting brackets for the head lights. You will end up spending way more than buying a 92.
Eric
13.4 @ 102.9
Big 16G @ 19 psi
Old 06-16-2002, 09:39 PM
BlkSprk's Avatar
ya know, i never thought of that, thanks alot
Old 06-17-2002, 10:58 PM
GST95 GST95 is offline
92 would be your best bet if you could find one that has a build date before may. These cars have the stronger early model 6 bolt engines and the stronger later model 4 bolt rearends. 90-91 used the same engine, but with a weaker 3 bolt rearend. after may of 92 changed to a 7 bolt engine that has smaller rods and a weaker crank.
95 Eclipse GST
91 Talon AWD TSI
91 Eclipse GSX
90 Laser Turbo
(soon to have) 93 Eclipse GSX
Old 06-22-2002, 11:19 PM
95 Eclipse GST
91 Talon AWD TSI
91 Eclipse GSX
90 Laser Turbo
You may want to seek councilling. DSMaholic if I have ever seen one.
Eric
13.4 @ 102.9
Big 16G @ 19 psi
questions about Eclipse interior light maqfancar Eclipse 2000+ 0 07-15-2005 02:06 AM
Question about Eclipse and talons frames GreddyEclipse Off-Topic 2 07-03-2005 09:54 PM
Question about Eclipse barb_wire_24 Off-Topic 4 08-03-2004 07:29 PM
plz answer question about 3000GT and Eclipse metalmachine 3000GT/Stealth 12 02-01-2003 01:30 PM
have a question about 90' eclipse???? a5ian5murf Off-Topic 1 05-27-2002 01:37 AM
