Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 12-10-2005, 11:32 AM
Bannon7414 Bannon7414 is offline
Send a message via AIM to Bannon7414
Question Good Ol' Horsepower
what are some easy ways to get increased horsepower? i am getting a K&N FIPK GEN II soon, but what else can i do? i have a 350 5.7L 94 caprice.
and also, i am looking to get painted in the next few weeks should i go with the factory blue that it was before or dark gray? my interior is navy bliue, what do you guys recommend
Old 12-13-2005, 05:25 PM
HLandin's Avatar
HLandin HLandin is offline
As far a color, I prefer, from my own personal experience, a white exterior with the blue interior (althought I prefer dark blue, aka Safire Blue, to light blue interior).
As far as mods go, I image basic hotrodding techniques will yield results here. Larger valve and/or higher compression heads, higher flowing injectors, larger throttle body and manifold, intake air cooler (cool air is more dense than warmer air), change of rear gearing ('94 has economy 3.08 ratio gears that give decent performance but 3.42 or larger will produce more torque at the rear end but may reduce top speed), hood scoop/ram air, going with larger lightweight alloy wheels (17" aluminium like Impala SS as opposed to stock Caprice 15" steel wheels), adding nitrous (although I shun nitrous as the hallmark of the ricer).
Limited-slip differncial (SPID - G80) should also help off line performance.
These are just some ideas.
Old 12-14-2005, 12:55 PM
etc. etc. is offline
I recommend doing a cold air intake, mufflers/ 2.5 in catback, PCMforless.com programming, 1.6 roller rockers and springs, TB bypass, and 3.73 gears with a new Eaton 400# posi. The 3.42 gears are a good choice if gas mileage is in mind, its said going from 3.08 to 3.42 isnt worth the money for the performance you get in return. If your thinking headers, Dan at clearimageautomotive.com has headers (Budget and Tri Y) which are MADE for these cars.
pssss. Try impalassforum.com for a lot more info.
etc.
Old 12-14-2005, 01:37 PM
mackamitsu mackamitsu is offline
Send a message via MSN to mackamitsu
Build up a 383, put it in front of the stock tranny, 2.5 inch headers, 2.5 inch dual exhaust, 2.5 inch high flow generic cats, 2.5 inch thunder chambers (the cherry bombs are a dead giveaway the engine is tweaked) . For the rear end I'd go either 3.73 or 3.42 depending on how much fuel you feel like burning (a moot point with a stroker IMHO). Then go play surprise the rustang.
Old 12-14-2005, 01:56 PM
1986Z28's Avatar
1986Z28 1986Z28 is offline
Has a Camaro
Send a message via MSN to 1986Z28
Re: Good Ol' Horsepower
underdrive pulleys, chip, exhaust, bigger injectors, etc.. BTW mackamitsu, he wants easy ways, and not everyone can build a motor and i doubt a stock 4l60e could handle the power of a 383
Formerly Blownalcoholboy
1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi)
Best ET 1/4: 8.35 @ 170mph (275 drag radial)
Best ET 1/8: 5.44 @ 132mph (275 drag radial)
Best 60': 1.31 on the back tires (275 drag radial)
AF User Rules/Guidelines
http://www.automotiveforums.com/vbul...uidelines.html
