Old 06-04-2002, 06:25 PM
soul180's Avatar
soul180 soul180 is offline
Car Problems...Please Help
Alriht, i actually have two problems:
1) The exhaust has a rattle noise when i'm driving, it happens between 3000-3500rpm, it usually goes away once the car is warmed up.
2) A strange noise, (wheep wheep wheep wheep wheep) is coming from the drivers side wheel well...i'm thinkin worn cv boot/joint...happens in turns and going straight...
Any help i can be given is much appreciated
Also, if it is the cv boot/joint, i am getting an engine swap in a few weeks...will that be replaced or should i fix it now?
UGSTYLES
Old 06-04-2002, 09:58 PM
RedRocketGSR's Avatar
RedRocketGSR RedRocketGSR is offline
Send a message via AIM to RedRocketGSR
The rattling is from the section from the pipe from the cat-back. The "wheep" noise is probably the brake pads going down to the warning mark. As for the CV, just wait on that because you will need new axels for the swap anyways. Good luck.
95 Integra GS-R
[email protected]
Old 06-04-2002, 11:31 PM
EightOhOne's Avatar
EightOhOne EightOhOne is offline
usually cvs make a clicking noise.
my car rattled like yours did, and it was caused by the heatshiled rusting out around a bolt and rattling against it. I solved this problem by getting a large hose clamp and tightened it around the heatshield/exhaust. No more rattle
Old 06-05-2002, 12:00 AM
-=BOOMER=-'s Avatar
-=BOOMER=- -=BOOMER=- is offline
Send a message via ICQ to -=BOOMER=- Send a message via AIM to -=BOOMER=- Send a message via MSN to -=BOOMER=- Send a message via Yahoo to -=BOOMER=-
don’t you meant the catalectic converter?
a cat back is useual in referance to a exaust that starts after the catalectic converter and goes all the way to the muffler.
Old 06-05-2002, 01:56 AM
hondaman-iac's Avatar
hondaman-iac hondaman-iac is offline
Send a message via AIM to hondaman-iac Send a message via Yahoo to hondaman-iac
du u feel like the steering wheel is shaking when braking ? might be the brake disk that is warped and touches the pad while rotating.
hondaman-iac @ HondaStyle
92 ACCORD LX -- powered by a blown F22A1
Current Mods:
*rear lower tiebar
*AEM CAI
*Koni Yellow Struts
*Ground Control coilovers
*Energy suspension bushing kit
*front upper strut bar
*rear upper strut bar
PureHonda member since April 2001
Old 06-05-2002, 02:16 AM
soul180's Avatar
i just replaced my brake pads....so they shouldn't be that worn yet...
the steering wheel doesn't shake at all....i don't notice anything except the noise....
so the exhaust is an easy fix...i figured the heat shield would be a problem...i'll strap iot up nicely
any other ideas for the wheeping noise?
UGSTYLES
Old 06-05-2002, 03:27 AM
it is the cv bood, which might be broken, and the shredded parts rub against the damper fork. take a look at that. i noticed that i get that sound after i noiticed the thorn boot.
Current Mods:
*rear lower tiebar
*AEM CAI
*Koni Yellow Struts
car problem PLEASE HELP QUICKLY!! andyrerick Lancer 4 02-02-2010 08:37 AM
Stupid Car problem!! Please help. HondaCivic4358 '88 - '91 Civic | CRX | Wagon | Shuttlee 24 08-30-2006 02:36 PM
97 Sunfire Car Problem - PLEASE Help SockaPlayR Cavalier Problem Diagnosis 25 03-30-2005 03:54 PM
1996 G20 Car Alarm problem. Please help me disconnect this thing! brianchevy General 0 05-28-2004 03:45 PM
My friend has car problems...please help. mellowboy '71-'87 Civic | CRX 8 03-13-2002 11:10 PM
