Old 08-21-2006, 07:23 PM
HondaCivic4358's Avatar
HondaCivic4358 HondaCivic4358 is offline
Send a message via AIM to HondaCivic4358
Exclamation Stupid Car problem!! Please help.
I was driving last night and I noticed that my temperature gauge went way up almost to the red. I also noticed that my clock and headlights were dim and later on, my check engine light came on. I was hoping just to get home, even though the car seemed to be running fine. I got home ok, then woke up this morning and forgot all about it. I got in my car took off, and not right away, but within about 5 minutes my check engine light came on again. My temperature gauge kept fluctuating from way up to way down, then I realized something. It either went up or down when I hit my brakes. Sometimes when I hit my brakes, the temp gauge would shoot way up, or drop down. I also noticed that hitting my brakes caused my cigarette lighter to short out, but letting off the brakes would me the power to it come on again. I noticed this because my radar detector kept turning on and off. My clock kept dimming when the brakes were hit as well. This must be a vacuum line, or an electrical problem. ANY ideas? Please help. Thank you.
1989 Honda CRX Si
D16Z6
2.5 in Exhaust
CAI
Chikara Header
Old 08-21-2006, 07:59 PM
FuLL BLown STD's Avatar
FuLL BLown STD FuLL BLown STD is offline
Send a message via AIM to FuLL BLown STD
Re: Stupid Car problem!! Please help.
dude juss check ur tire pressure on the passenger side tire..happens to me all the time..hope this helps.
Old 08-21-2006, 08:02 PM
wtf? i hope your not serious. lol
1989 Honda CRX Si
D16Z6
2.5 in Exhaust
CAI
Chikara Header
Old 08-21-2006, 08:07 PM
jeef jeef is offline
Send a message via AIM to jeef Send a message via Yahoo to jeef
perhaps your alternator is on the way out....
90- crx si w/ a D16a Vtec and a few goodies, oh and 60k miles on it heh
Old 08-21-2006, 08:32 PM
good point...possibly...
1989 Honda CRX Si
D16Z6
2.5 in Exhaust
CAI
Chikara Header
Old 08-21-2006, 08:46 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Check all of your grounds. Most likely problem.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 08-21-2006, 09:02 PM
CRXperiment's Avatar
CRXperiment CRXperiment is offline
First get your CEL code, its most likely a code 20 for electric load. Then as stated above, check your tranny to battery, valve cover, and thermostat ground. After that you might wanna check your dash harness and brake wiring, they could have gotten mixed up and melted together thereby causing electric signals to be sent to your temp guage intsead of your brake lights, when you brake.
1989 Civic STD - sold
1991 CRX Si - current
Free Service Manuals: http://hondatech.info/
Old 08-21-2006, 09:19 PM
Hybrid1990crx's Avatar
i 3rd to check you grounds for sure, probably corroded or not attached.
Old 08-22-2006, 12:10 AM
hondacivic99sivtec's Avatar
hondacivic99sivtec hondacivic99sivtec is offline
Send a message via Yahoo to hondacivic99sivtec
i 4th that idea.
-tony-
2000 honda s2000
Old 08-23-2006, 04:29 AM
integra96lsvtec integra96lsvtec is offline
checking the grounds is ur best idea
96 integra ls/vtec, b16a head on a b18 block golden eagle conversion kit, injen intake, arp rodbolts, dc headers, custom 2-1/4 exhaust with magnaflow muffler,
US NAVY
Old 08-23-2006, 07:48 AM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
First, check the codes. Then after that maybe you should take the time to investigate your wiring. Sounds like you have a short somewhere.
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 08-24-2006, 03:22 AM
sparkeykev sparkeykev is offline
Send a message via Skype™ to sparkeykev
check for short in brake light wiring also trailer hitch wiring if you have it seen many with trailer plug wiring shorting on exhaust
Old 08-24-2006, 03:47 AM
ryan you say that like your questioning us. what would you do mr. smart ass?
-tony-
2000 honda s2000
Old 08-24-2006, 11:57 AM
ok...so now i am going to sound really stupid, and i know people flame for totally retarded questions, but if anyone could help me out by telling me how i go about checking the codes. i know where the ecu is at and the light, but i dont know if there is a right way. like turn the ca on....or accessory position or what. i dont know how to read the codes either.
1989 Honda CRX Si
D16Z6
2.5 in Exhaust
CAI
Chikara Header
Old 08-24-2006, 12:28 PM
Just turn the car on, pull back the passenger side carpet and start counting blinks. When there is a significant pause, stop, then start over again. If the same number of beeps repeats then it is just one code. If there is then a different number of beeps you have two codes, etc. OBD0 d-series engines go one beep at a time. Check the FAQ thread for the code chart.
2010 Honda CR-V EX
