Old 06-04-2002, 04:11 PM
Laker's Avatar
Laker Laker is offline
ZCGUYS! starting Issues help (end swap)
My friends ZC is having troubles starting after his swap
Everything looks good, But it wont turn over
turns the key, all you get is the starter, wont kick in
I faintly smell gas as well (might just be me on crack though)
Any suggestions where to look first?
Old 06-04-2002, 05:31 PM
optimuspeterson optimuspeterson is offline
Send a message via AIM to optimuspeterson
well we did Traivs_118's swap his starter was bad that came with the tranny. All it would do is click. so we swapped starters out. then finally we had the plug wires wrong and then it started up.
http://home.bendcable.com/optimuspeterson/ <<<<HRC Stage 2 and Star Instructions
95 GS
Mods: Probably a whole lot more than you.
Old 06-04-2002, 06:19 PM
Laker's Avatar
Strange
Thats the thing, it ALMOST starts
i dont know how to describe it lol
It turns over, but wont ignite
Old 06-04-2002, 06:45 PM
Bleebdat Bleebdat is offline
Send a message via AIM to Bleebdat Send a message via Yahoo to Bleebdat
Have you guys made sure you have spark, if you do next step is to make sure your timing is correct, if your timing is way off the car wont start. Inspect those two things, and then come back if it still isnt going.
Old 06-04-2002, 07:39 PM
travis_118 travis_118 is offline
Send a message via AIM to travis_118
yeah mine was doing the same thing. it would almost start but not quite. It was my pulg wires they were on the dizzy incorrect. double check that.
1997 Toyota 4Runner Limited
Built ZC in 90 Civic std model....
as marked001 says Don't click here
Old 06-08-2002, 02:56 PM
brightazzsi brightazzsi is offline
had same problem with mine
first check for spark, if u have spark pull your injector rail and injectors. mine were dirty and hardened up i took mine out of my factory si motor and it started right up!! good luck
Old 06-08-2002, 03:35 PM
reXem reXem is offline
When I did my swap there were two wires the same color that had to be moved to the ZC Plug....it was a matter of testing to get them in the right spots...one way the engine wouldn't fire and the other obviously it worked...so look at that....also your firing order on the cap could be wrong....I believe it goes 1-3-2-4 (correct me if I am wrong ) I am also fairly sure if you look at the cap there is a C on it and that is 1....hope some of this helps
WONT START, need help fig. out what the hose is 4 mrs.k.m.ashby Grand AM 0 02-12-2011 05:07 AM
Help! Starting issue sunfire96 Problem Diagnosis 5 04-12-2009 11:57 AM
1995 xj6 Starting issues Help please Kristoff XJ6| XJ8| XJ12 | XJR 1 04-02-2005 01:04 AM
3.2 L Starting issues ....help! Glassrodeo Rodeo | Passport | MU 1 10-12-2004 03:41 PM
97 nissan maxima weird starting issues... HELP!! weadwhacker Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 9 01-15-2004 06:25 PM
