Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 10-12-2004, 01:25 PM
Glassrodeo Glassrodeo is offline
3.2 L Starting issues ....help!
Well all let me say to all of you thank you for so much information you have all posted on this web site! I have a 1999 Rodeo LS that has already had the engine replaced, the SRS Coil Assembly inside the steering wheel, the relay and control module for the wipers, The EGR valve just a few weeks ago, ...... the list is long! Oh when will it stop!
Any way, The engine dies imediately after i hear it fire up and let go of the key! I can always get it started but it behaves this way at pretty much every start. Usually after it starts it idles crazy for a bit. The idle speed after it settles down, seems fine at about 750 (Auto Tranny). The fuel pump is priming as the key is turned on (can hear it). Once i get it going and stable, it will not stall or act weird at all.... it does tick or sound a little like a diesel but that is another issue io believe. I am still very frustrated with the shop that did my Engine change..... Dont ever go to Weassels repair in Rapid City, SD. If the throttle is pressed a bit, it seems to start better. I have read my Haynes manual three times and am thinking it may have a bad fuel pressure regulator.... If any one has any innput i would surely appreciate it!!
Glasspack
"Glasspack"
1991 Rodeo LS
1999 Rodeo LS
Old 10-12-2004, 03:41 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: 3.2 L Starting issues ....help!
It could be a bad intake manafold gasket too.
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
