Old 06-03-2002, 05:33 PM
Kosmonaut Kosmonaut is offline
Send a message via ICQ to Kosmonaut
help, paint not going on smoothly
i am using tamia white with tamia thinner
but for some reason the paint keep on splattering and leaving a coarse finish
what could be causing it?
Old 06-03-2002, 06:29 PM
anyone????
Old 06-03-2002, 06:31 PM
MX100's Avatar
MX100 MX100 is offline
Send a message via ICQ to MX100
ummm? wat paint?
spray can?
Acrylic?
Current Project: Tamiya Nissan Skyline R34- 70%
Next Project: Honda S2000 type V, Subaru Impreza WRX STi, Modulo DC5, Veilside MRS
http://community.webshots.com/user/a_bathing_ape
Go to that site to view images of my models and other car pics..enjoy!
Old 06-03-2002, 06:39 PM
acrylic
airbrushed
Old 06-03-2002, 07:02 PM
daggerlee's Avatar
Hm....PSI may be too high, try using a lower PSI. If it's a double action, don't pull all the way back, try putting it on more fine. Try thinning it more too, and remember thin light coats are the key. Also, when you're spraying, don't spray directly onto the model, start outside and sweep your way across.
Dan
Old 06-03-2002, 07:05 PM
it's really weird
if i use a low PSI the paint splatters or doesnt come out at all
and if i turn it up, it comes out chunky
but the paint is really thin, thinner than what i usually use
Old 06-03-2002, 07:14 PM
Vric's Avatar
Vric Vric is offline
I got the same problem 2 day ago with Tamiya Paint.. I used Testor Acrylic and it worked fine.... don't know why, I can't get tamiya paint to work with my airbrush..
Maybe tamiya paint dry too fast in my paintbrush..
Old 06-03-2002, 08:50 PM
daggerlee's Avatar
How thin are you thinning your paint? It should be the consistency of milk. Also, your paint may not be mixed well enough - you need to stir it with a toothpick and really get the gunk at the bottom of the jar.
Dan
Old 06-03-2002, 09:04 PM
nikanora nikanora is offline
Send a message via AIM to nikanora
What i ussually use to stir up my paint are the sticks/bars from the now empty and useless model trees. i just cut out sticks long enough and use them, works better than toothpics for me.
Also make sure your not either too close or too far away from the model.
nika
Old 06-03-2002, 09:10 PM
its a little thinner than milk consistency, or the usual paint consistency i use
i tried thinning it even more, and doing a rim
the paint went on smoothly, but didn't dry glossy
WTF is going on
Old 06-04-2002, 05:28 AM
ninjaboy20 ninjaboy20 is offline
one problem solved....
hey Kosmonaut....
The only problem i can help you with is your lose of glossiness when you thin your Tamiya paints. the reason why is doesnt have a glossy shine after you mix the thinner is because you added too much thinner.....A local hobby shop told me to only add 1 part thinner to 3 parts thinner.....any more could be the result of lose of glossiness....sorry i dont know whats causing your clumpy paint....i dont have an airbrush....i use compressed air cans....cant really afford one yet hope this helps
Old 06-05-2002, 02:43 PM
Scorp21 Scorp21 is offline
Re: one problem solved....
Originally posted by ninjaboy20
hey Kosmonaut....
You can afford an Acura Integra but you can't afford a new airbrush?
Old 06-05-2002, 03:03 PM
ales's Avatar
ales ales is offline
Forza Schumacher
Re: Re: one problem solved....
That's not too nice of a first post, is it?
please help! -paint estimate helpme1234 Auto Collision Network 1 06-19-2010 07:11 AM
not running smooth wilkinsj M Bodies 2 07-05-2009 12:45 PM
Brake job not going smoothly... 9c3 Lumina 10 05-17-2007 09:55 AM
How to brush paint metal colours smoothly? yellow15 Car Modeling 2 05-04-2003 10:20 PM
the changes are not going too smoothly ales Formula-One 11 01-22-2003 06:59 PM
