Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 06-03-2002, 05:26 PM
HookdUpTeg99 HookdUpTeg99 is offline
Should I get this???
Would a Garrett T3/4 turbo work well with my car? How much boost could i run safely on my stock internals (keeping in mind i only have 26k miles on my car) and how much hp could i realistically look to gain from this? Thanx alot.
'99 Red Integra LS
- Ground Control Coil-Overs
- KYB AGX Adjustable Shocks
- 17" Konig Toxxins w/
205/40/17 Kumho Ecsta Supras
- Mid-Wing Spoiler w/ LED
- Injen Cold Air Intake
- Pioneer Head Unit w/ Animation
- JL Audio 250/1 Amp
- 2 10" Alpine Type-R Subwoofers
- Reverse Indiglo Titanium Face Gauges
- Hyper White Headlights
- Clear Corners
Old 06-03-2002, 07:32 PM
JD@af's Avatar
JD@af JD@af is offline
Missing in action
Send a message via ICQ to JD@af Send a message via AIM to JD@af
I'm not 100%, but I am pretty sure that with the proper exhaust manifold and other plumbing (down pipe, etc.), a Garrett T3/4 will be just fine with your engine. Ideally I'd want to have 40K miles on a factory engine before going forced induction, but 26K is a lot better than 10K, so I'd say you can go for it. You can handle 6 psi without much drama; if you want to push it up to 8 or 9 psi on factory internals, you should make sure you get some dyno tuning to make sure everything is running as it should be (and pay attention to the little details like the proper spark plugs, timing adjustments, and of course octane), and you should not hit it too hard too often (use your judgment). As for horsepower, figure 10 or 11 horsepower per psi of boost, or 12 if you get lucky. It also depends on whether you build everything else right around the turbo: at 6 psi, you can probably get away with stock everything, but as you increase your power, you'll need bigger exhaust plumbing, a higher flow capacity intake element, eventually a bigger intake manifold, etc.
Old 06-03-2002, 11:30 PM
kane2g kane2g is offline
Send a message via Yahoo to kane2g
add an intercooler. it will add some more power.
92 fastback 240sx AKA Ess1Tree Cuz its green, and hasn't moved in months.
Think I should get this rear lip? *pic* 99civic03 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 12 02-03-2004 03:54 PM
Should i get this? CivicOwnage '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 4 01-15-2002 11:42 AM
Should I get this bodykit??????? MD99SiR '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 13 12-17-2001 06:52 PM
Should i get this Rear Diffuser or Not??? P11GT General 10 10-05-2001 07:17 PM
Should i get this? VicenteFox Car Modeling 5 08-12-2001 11:04 AM
