Old 12-01-2005, 03:03 PM
taryn328 taryn328 is offline
wont shift out of park!
I have a 1997 ford taurus. I started the car and it wont shift out of park. The strange thing is that if I put it into acc. I can shift just fine, so I have been putting it in acc. then shifting into nuetral and then turning the car on. Has anyone ever had this problem?
Old 12-01-2005, 10:58 PM
KimMG KimMG is offline
AF - Advisor
Re: wont shift out of park!
Check the brake pedal switch.
Old 12-03-2005, 05:59 AM
Millermagic Millermagic is offline
A bad brakelight switch is most likely the problem like Kim said. But putting the key where you do is the only way to get around it for now.
Old 12-12-2005, 03:51 PM
So then, how do you propose that I fix this problem...like I said I really dont know anything about cars! Your help is much appreciated!
Old 12-12-2005, 07:55 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Switch is easily replaced. It is located on the metal part that goes up under the dash on the brake pedal. You may need to remove the lower part of dash to gain easier access. Look at the connector on the switch too. These are bad about burning and allowing the wires to break conection on the switch. A shop should not be too expensive to repair this if you do not feel comfortable trying to repair yourself.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
