Old 06-02-2002, 08:16 AM
SlammedCivicSedan's Avatar
SlammedCivicSedan SlammedCivicSedan is offline
Send a message via AIM to SlammedCivicSedan Send a message via Yahoo to SlammedCivicSedan
Power Pulleys/Cam Gears
hey,
which will give me more HP, Power pulleys or cam gears?
which is easy to install?
can io do it myself?
i have a SOHC civic 99 auto.
All i have in the engine is a short intake.
thanks for the help.
:help:
Rattltrunk
Cardomain
2007 Mazda Mazda3
2003 Suzuki Aerio
[email protected]
Old 06-02-2002, 09:21 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
the cam gears would prolly give you more HP, especially if they are adjustable. they are easy to do, if you have some common sense as to how to remove something and put it on correctly. but a Helms, or a chiltons manual would be your best route.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 06-02-2002, 09:24 AM
how much HP can i gain with a Sohc d16y8 ?
Rattltrunk
Cardomain
2007 Mazda Mazda3
2003 Suzuki Aerio
[email protected]
Old 06-03-2002, 05:57 PM
Frostbyte Frostbyte is offline
Send a message via ICQ to Frostbyte
Why not get both?
1989 s13 Fastback
Tein HE coil-overs
sr20det swapped!
JIC Magic Front and Rear Strut Bars
Slotted and Cross-drilled Rotors
S/S Brake Lines
Pivot Lazy eye controller
Blitz LM Intake
Blitz D1 Spec Turbo Timer
Soon to come:
Sard 550cc Injectors
Blitz Nur Spec Exhaust
Blitz Down pipe
HKS FMIC
http://www.driftmonkey.com (Part Owner)
Old 06-10-2002, 06:12 PM
RedRocketGSR's Avatar
RedRocketGSR RedRocketGSR is offline
Send a message via AIM to RedRocketGSR
Well the cam gears would give more HP, but the pulleys are easier to install. You can definitley do both with just a good manual and some common sense. You'd be lucky if you got 10hp out the cam gears AND pulleys....which isnt too bad tho. Good luck.
95 Integra GS-R
[email protected]
Old 06-10-2002, 09:36 PM
piscorpio piscorpio is offline
Send a message via AIM to piscorpio
10 hp is a reach. Ive heard from people who have had em', you can't expect too much, especially on a SOHC. (SCC claims about 2-3 hp from underdrive pulleys on a dyno for most cars they have seen, but its a consistent 2-3 hp ) Im not saying they aren't worthwhile though, especially in the case of the cam gear, since it gives you a new dimension of tunability. I suppose that could be helpful if you mod the engine more in the future. This is just one of those "get everything else first" mods it seems...at least that is what most people have advised me.
Old 06-10-2002, 09:37 PM
Also, remember that with the cam gear, you really would have to access a dyno to get good results from it. Otherwise you would be tuning blindly so to speak.
92 deville 4.9 Power Steering Pulley sheered / fell off and destroyed belt! 92Deville Deville 1 06-03-2009 06:51 PM
cam gears & Pulleys?? AnGeLoBBoy Engineering/ Technical 5 12-15-2002 12:28 AM
Pulleys and cam gears? kush187 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 0 08-17-2002 10:58 AM
Cam Gears and Power Pulleys integred Forced Induction 2 08-05-2002 11:01 PM
