Old 11-27-2005, 09:22 PM
kyuuketsuki kyuuketsuki is offline
Question painting the side view mirrors
Hi all,
I am new here. I have a question about painting side view mirrors of a vehicle.
I have difficulty in painting those mirrors. They never come out right ie, bubbles, rough paint surface, anything you can think of, they happened whenever I paint those mirrors.
I get so upset that the entire model is 'destroyed' from that bad paint.
I would greatly appreciate any tips, hints on painting the mirrors. Also, how can i remedy those that i have painted and ruined.
Thank you.
Kyuu
Old 11-27-2005, 09:33 PM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
Re: painting the side view mirrors
I usually spray paint or airbrush them. Are you brushpainting?
-Mike
Old 11-27-2005, 09:35 PM
freakray freakray is offline
AF Modelrater
I spray or airbrush mine too, never had a problem.
AF User Guidelines
Old 11-27-2005, 09:38 PM
Lambo003's Avatar
Lambo003 Lambo003 is offline
Are you talkin' about the mirror surface itself or the entire mirror housing???
Housings should be sprayed right along with the model to eliminate any sort of color difference.
Mirror surfaces are best represented my either Bare Metal Foil or Mylar. Mylar looks the best though!
Calm down, brutha! It only gets better
Originally Posted by kyuuketsuki
Hi all,
Thank you.
Kyuu
Chuck
Old 11-27-2005, 10:22 PM
blubaja's Avatar
blubaja blubaja is offline
Welcome to AF!
Old 11-27-2005, 11:51 PM
thanks for the tips.
yup, im refering to the mirror case. I spray painted the mirrors.I dont understand why the bad result.
So how do i remedy those already in bad shape?
Can i use thinner to 'wash' off the paint and restart again?
In the future, do I attach the mirrors to the body of the car first and spray paint both parts together?
thanks all!
Old 11-28-2005, 12:22 AM
redstang423's Avatar
redstang423 redstang423 is offline
i'm not sure what everyone else has experienced, but i have found you can use thinner and some light scrubbing to remove paint if hasn't dried completely. if it is hardened or that doesnt work, there are many different ways of stripping the paint on here including soaking in brake fluid and oven cleaner... a quick search or if you hit the FAQ's will give you plenty of infoto that end.
for the mirror case, if it is body color, i glue it to the body right away before priming and spray it all as one unit. be careful you dont get a "shadow" lacking paint from doing that though.
Jeff
In Progess: Corvette C5R (95%), 1995 Corvette ZR-1 (97%), 1968 Shelby GT500 (15%), Porsche 911 Slantnose (99%), Nissan 350Z track (80%)
To Be Started: Ferrari F50, Porsche 911 GT3, Mitsubishi GT0/3000GT
Recently Finished: 1999 Ford SVT Lightning
liveSTRONG
