Go Back   Automotive Forums Car Chat > Hyundai > Tiburon | Tuscani
Old 11-24-2005, 07:52 PM
Mattmd Mattmd is offline
Installing new plugs and Wires. HELP!!!
I have some OBX plugs and aftermarket wires I want to install in my 05 Tib GT but am not sure of the best way to go about it. Does the plenum have to be removed to get at the three plugs in the back? Can anyone outline the procedure for doing this for me and let me know if there is anything else I will need to do this installation on my plugs.
Old 11-28-2005, 08:47 AM
lowsonoma1999's Avatar
lowsonoma1999 lowsonoma1999 is offline
Authorized Vendor
Send a message via AIM to lowsonoma1999
Re: Installing new plugs and Wires. HELP!!!
Yes you will have to remove the plenum to get to the back plugs. The plenum gasket is thin metal. If you are carefull enough, you can get it done without have to replace it. If you get any bends or kinds in the gasket, you will need to replace it. Front ones are self explanatory. Back ones, remove all cables and hardware that is connected to the plenum, unbolt the plenum and lift off, then you can get to the plugs easily.
John Nance
Parts Manager
Terry Lee Hyundai
17665 Terry Lee Crossing
Noblesville, IN 46060
Old 11-28-2005, 10:13 AM
Re: Re: Installing new plugs and Wires. HELP!!!
Are their any special torque settings for replacing the plenum after removing it? Thanks for the info.
Old 11-28-2005, 04:30 PM
tibby01 tibby01 is offline
man, that must fucking suck. i can change mine in like 2.7 minutes.
Old 11-28-2005, 07:12 PM
Yeah it does, But my Tib will whoop the shit out of yours.
Old 11-28-2005, 09:26 PM
easy there pal.
i was going to go into webtech and find out those torque numbers for you. hmmmm...good luck finding them. do some searching.
and before you go making assumptions, you should realize what you are going up against. I havent been to the track lately, but i could easily beat a stock v6 with what I have done. im going to go ahead and assume your car is stock, what with the obx plugs you are getting.
in a real race, you wouldnt even stand a chance. i would pwn you in autocross, hands down. again, unless you are an idiot with crazy awesome ub3r cool mods getting some obx plugs.
Old 11-28-2005, 09:58 PM
easy there pal.
Sorry, didn't mean to come across that way. I was just talkin some shit. No disrespect intended. My car is basically stock. I have a SRI, I actually think I am going to wait on the plugs since I found out I have NGK's iridium plugs anyways. I may do the wires still though. Not sure if it is worth removing the plenum and everything just for wires though. I doubt my obx plugs will be better than the NGK plugs I already have. Let me know what you think. Again sorry for saying what I said, I didn't mean to disrespect anyone.
Old 11-28-2005, 10:07 PM
no man, its cool. word of advice...stick with ngk plugs and wires. tried and true, and cheap.
and since you asked nicely
intake manifold to head is 14-15 lb. ft. thats a low number, and you definately dont want to snap anything, so make sure you step to the spec torque. go to 8-9 and then 14-15.
Old 11-28-2005, 10:16 PM
Any way you could send me the link to where you found that info. I greatly appreciate it. So what do you have done to your Tibby?
Old 11-28-2005, 10:28 PM
http://www.automotiveforums.com/vbul...hlight=webtech
things im doing now...
http://www.automotiveforums.com/vbul...d.php?t=476786
im going to have to make a mod list up. basic go fast straight stuff, along with just about every suspension mod available.
Old 11-29-2005, 11:14 AM
Authorized Vendor
Re: Re: Re: Installing new plugs and Wires. HELP!!!
You might want to pull a front plug and find out for sure. Sometimes they come with Champions from the factory. For replacements, Hyundai offers the Champions and NGKs. Of course, almost all dealers replace them with the NGKs when it comes time for them to be replaced.
John Nance
Parts Manager
Terry Lee Hyundai
Old 11-29-2005, 11:53 AM
Re: Re: Re: Re: Installing new plugs and Wires. HELP!!!
I did pull one of the front ones and it was an NGK plug. Thanks for the advice. Can you find out what the torque specs for replacing the plenum are for me? I would greatly appreciate it.
Old 11-29-2005, 12:00 PM
above
