Go Back   Automotive Forums Car Chat > Hyundai > Tiburon | Tuscani
Old 10-31-2005, 03:08 PM
tibby01 tibby01 is offline
Many Many Mods(56k Killer) (progress pics)
finally decided i needed to catch up on all the things i had to do to the tib before i started adding more stuff to the list. its really slow going what with school and my two other jobs right now, but im able to fit in a good couple days on the weekends. though it might be interesting for other people to see what pics i can take along the way.
my chariot while the tib is down:
it actually rides quite nicely(big difference from the coilovered tib) and gets decent gas mileage. but god damn i cant wait to get the tib back on the road. the truck is SLOW, primarily because i dont want to rev it anywhere near 3k. it has 130k miles on it, is a ford, and is not mine and i dont want to pay for anything that breaks. so ive been driving like a grandma lately.
anywho, this is the list of things that will be accomplished by the end of it all:
1. sound deadening
2. internal, amplified radio antenna
3. alarm w/remote start and following features:
  • keyless entry
  • hatch pop
  • sunroof/window roll up and down
  • 2 closed loop sensors
  • backup battery
  • 9 tone siren
  • interior piezo pain generating siren(hurts bad)
  • shock sensor
  • tilt sensor
  • microwave(proximity) sensor
  • glass break sensor
  • many more that i cant think of now
4. seat heaters(to be activated by alarm as well as switch probably)
5. complete led fogs and tails using premade breadboards, not led bulbs.
6. All lights will be leds(except HIDs)
7. make new courtesy light covers using a plastic molding and casting kit.
8. re-route washer fluid lines and squirters to wiper cowl(dont want to drill through my new cf hood )
9. two additional interior fuse blocks. one ignition, one constant.
10. retint windows. kinda messed up my first time around. cut a little to much off in some spots, never did complete hatch glass(after trying 3 different cut-outs). first one wasnt even close, second ended up wrapping back on itself before i even got it out to the garage, third was really close, but i didnt make the little "fingers" small enough, and i couldnt shrink them enough to make em flat. having to remove tint residue from the hatch glass once before, i quickly tore it off before it could dry and decided i would give it another try some other day.
11. 1.8l ecu. i do have one, not to sure if ill put it in yet.
12. hidden garage door opener somewhere in the car. picked up a tiny switch for it, thinking glovebox would be a good spot.
13. shark spoiler i still have to mold further and paint(will attempt with rattle can). it will have a blue and red brake light, with a switch i can change that will also be fore the red/blue tails i will have. :sasmokin:
14. bunch of other random led/neon things here and there. def. wont over-do it though, im starting to lose grips with the ricey side of me.
15. paint a bunch of things. so far, wiper cowls and door panels glossy black(had rest of interior glossy black, just never got to driver side panel). spark plug cover and front SB a much nicer shade of blue than i had before. considering painting the actual wiper arms too.
16. autodimming, compass, and temperature rear-view mirror. dims everything to a nice shade of blue, its sweet.
i think thats all. now on to the things ive done so far(with pics) along with picture of things still to come...
i decided to rip everything out to make the whole process easier:
everything out, and surface cleaned:
and front bumper because i had to swap out a bad ballast on my HID kit:
the graveyard of parts everywhere:
now the sound deadening. im using edead v1. 120 sq ft. for 100 bucks on ebay. i couldnt pass it up. i still have to cover a bunch more spots. its going slow b/c i dont want to cover any wires up and getting the f***ing clips out that hold the wire bundles to the body is a HUGE PITA. taking off every crew and then putting it back in means about 200 screws in all. i seperated all in nice little baggies and labeled them though :lmao: . I have already layed down about 75 sq. feet one layer everywhere, and then ill go back and hit the layers that i think still need it. i ripped that peice of shit heat cover(the one around the shifter assembly) out too. i was using a heat gun to soften the edead and decided i would test the crap. it friggin MELTED.
so ive covered the entire floor, and most of the sides and roof. still have to do doors and hatch. i MIGHT do the firewall, but thats gonna be a pain.
pics:
also did the sunroof:
but then i realized that when i got everything bolted back together, you could see some of the silver backing from behind, as the interior cover is only so big. so i gave it a couple quick coats of primer and paint, and now its barely noticeable:
painted a few peices here and there:
(close up of the taped off paint job, just for you redz... )
(just primer, they are painted same color as SP cover)
shots of some various things:
my new cf hood...
shark spoiler...
mirror...
tails and fogs torn apart, awaiting leds...
and the hyundai keyless entry brain i took out, alongside a DEI alarm that i guess the previous owner had installed. i guess ground was just cut off from it. in fact, writing this post i am remembering a very odd ground screw and crimp terminal without any wire running to it. solves that mystery...
uh yeah, thats all for now. snapped two bolts today, kinda pissed about it. one is the mounting stud for the top part of the sunroof(yeah, bad. hope there is no vibration and that the other 3 hold good enough). other is the bolt that holds the metal center console bracket(right inbetween the front seats; the thing the console screws into) to the body of the car. anyway, figured i would post up some pics, maybe give some people ideas. also thought it would be good to split things up, i will have tons of pics at the end and probably wouldnt have felt like taking the time to make a super huge post. this was long enough. ill probably be updating this thing every sunday, after i get done a good chunk of stuff.
Old 10-31-2005, 04:08 PM
DJ SlipStream DJ SlipStream is offline
Send a message via AIM to DJ SlipStream
Re: Many Many Mods(56k Killer) (progress pics)
wow thats amazing. how much money are you thorowing into this thing overall??
One of these days
Old 10-31-2005, 04:22 PM
overall, or just this stuff?
most of this stuff is cheap DIY type stuff. all of this mentioned above is definately less than 1k total, even with the cf hood and spoiler.
all in all, id say im up around 3k spent on the car. coilovers and sway bars are my two largest purchases so far.
Old 10-31-2005, 04:32 PM
BigTDawg BigTDawg is offline
Send a message via AIM to BigTDawg
rangers are awesome and its so nice to see a 4 cyl
Old 11-01-2005, 12:33 AM
nisco nisco is offline
Tib Guy
Send a message via AIM to nisco Send a message via MSN to nisco
thats a very nice sound-deadening job, tho i dont know how the quality is with that stuff... hope it works out well
the painting looks AMAZING!.. a very nice job all around with teh paint
almost that time
my sig made mommies cry, thats why i had to change it..
Old 11-01-2005, 12:54 AM
Underground_Killah's Avatar
Underground_Killah Underground_Killah is offline
Registered User
wow, very very awesome work... i'm speachless... i want to do that to my girl's tib...
Old 11-01-2005, 05:57 PM
speeddemonGtV6 speeddemonGtV6 is offline
Send a message via AIM to speeddemonGtV6
man it looks awsome, good luck to you with that much work....
WANNA RACE?
Old 11-01-2005, 07:33 PM
Re: Re: Many Many Mods(56k Killer) (progress pics)
well, the adhesion is great, and it definately wont be pulling off in extreme heat or cold. dipped down to the thirties one night and it held on fine. ive been using a heat gun to really soften it up before putting it on, and after it dries in place the heat gun just makes it really hot.
the only other brand i was considering was fatmat. dynamat just sucks and is overpriced, and bquiet is just to expensive. this was a bit lighter than fatmat, and a ton cheaper.
Old 11-15-2005, 07:19 PM
done with the sound deadening...
Old 11-15-2005, 08:07 PM
Registered User
wow... simply wow... hell don't even install anything in it... i'd like to see what that runs at the track lol talk about weight reduction!
Old 11-16-2005, 05:53 PM
Gaiiden's Avatar
Gaiiden Gaiiden is offline
Looks nice. What exactly does sound deadening do?
Drew Sikora
Proud Tuscani Owner
My Ride
Old 11-16-2005, 09:29 PM
make music sound better, eliminate road/wind/engine noise, get rid of any rattles.
Old 11-17-2005, 12:09 PM
Gaiiden's Avatar
Cool, that's what I figured
Old 11-18-2005, 09:08 PM
ItzmyCRX's Avatar
ItzmyCRX ItzmyCRX is offline
Send a message via AIM to ItzmyCRX
What ideas do you have for the stereo? I sound deadened my whole tibby also and put in 1 12" diamond tdx in a fiberglass enclosure with 2 diamond 1500.1 amps running it. can hear it from a couple blocks away
Why live long, if you can live fast?
Old 11-19-2005, 10:49 AM
nothing yet, im fresh out of money and snowboarding season is quickly coming.
id like eventually get infinity equipment. 2 10' kappas with a mono sub, and then kappa component all the way around with a seperate amp. i think i will go for some more speed before that though.
