Old 11-23-2005, 08:30 PM
mr2union mr2union is offline
Orange Peel with Metallic Paint
Happy Thanksgiving for those who are in the USA.
I have a question: I just put on the final coat of Metallic Red Paint on my model RX8. Before this last coat, I didn't think there was any Orange Peel. Now the final coat is drying, it appears that there is some Orange Peel. Knowing that I need to spray Clear coat on it in about a week or two, should I sandpaper the body before the Clear coat? Or I should just spray the Clear coat on and it will take care of the Orange Peel?
Please advice. Thanks!
Old 11-23-2005, 09:16 PM
freakray freakray is offline
AF Modelrater
Re: Orange Peel with Metallic Paint
Spray the clear on it before doing and sanding/polishing.
AF User Guidelines
Old 11-23-2005, 09:17 PM
RallyRaider's Avatar
Zomby Woof
If I were you I'd sand it back (be careful not to uncover primer - you used it didn't you?) then shoot another coat of metallic. Real thin to avoid any further orange peel then clear coat.
Old 11-23-2005, 11:30 PM
the orange peel is not very severe, so I'm still not sure what I should do. This is the third time I painted this body. I tried sanding the first paint job, but it went to far and into the primer, so I had to strip it and repaint it.
What grade of sand paper should I use? I have 600 and 1500 on hand now.
Old 11-23-2005, 11:54 PM
redstang423's Avatar
redstang423 redstang423 is offline
you would definately want to use the 1500 if you are going to sand. take caution because metallic paints tend to lighten significantly more under sanding that other paints, so you don't want a spot of mismatching color.
Jeff
In Progess: Corvette C5R (95%), 1995 Corvette ZR-1 (97%), 1968 Shelby GT500 (15%), Porsche 911 Slantnose (99%), Nissan 350Z track (80%)
To Be Started: Ferrari F50, Porsche 911 GT3, Mitsubishi GT0/3000GT
Recently Finished: 1999 Ford SVT Lightning
liveSTRONG
Old 11-24-2005, 07:58 PM
Thank you for your comments. After long consideration, I think I will just put on the clear coat and then polish & wax it later. I have repainted this kit three times and sanded the plastic so much, I don't want to sand it again. If I sand directly to the paint, I am risking it and may need to strip and paint the whole thing if any mistake.
Thank you anyway for the suggestion.
Old 11-26-2005, 03:43 AM
LS1Aaron LS1Aaron is offline
You should not polish or sand metallic finishes,polish the clear,and you will always have orange peel.
Old 11-26-2005, 04:36 AM
ales's Avatar
ales ales is offline
Forza Schumacher
Put it under running water - if it hides the orange peel, then so will a clearcoat. If not - take Rallyraider's advice.
