Old 11-22-2005, 06:49 PM
pimp349's Avatar
pimp349 pimp349 is offline
Send a message via AIM to pimp349
Question Street Legal HP
Can someone PLEASE explain to me if horsepower has anything to do with being street legal? And if yes how much is it ad how do they find out?
Old 11-22-2005, 11:48 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: Street Legal HP
No, hp has nothing to do with being street legal.
Old 11-23-2005, 11:08 AM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
Re: Street Legal HP
choosing the amount of hp a car company ultimately ends up with is based on many factors. Its mostly internal at the company, but its a dance around projected insurance costs (higher hp cars cost more to insure and it affects sales), reliability of the engine at certain horsepower levels, target customer, etc.
Dragging people kicking and screaming into the enlightenment.
Old 11-23-2005, 01:23 PM
mazdatech177 mazdatech177 is offline
Re: Street Legal HP
but some things you do to increase power might not be exactly legal... but its only illegal if you get caught
Old 11-23-2005, 02:27 PM
pimp349's Avatar
Re: Re: Street Legal HP
Thanks for clearing that up. Someone keeps telling me that 500 and under is street legal but that would be rediculous since the Murcielago, Enzo, CCR, etc make over that amount officially, from the factory.
Originally Posted by curtis73
(higher hp cars cost more to insure)
How do insurance companies know what hp your car has? Most blown civics make 2 or 3 times their orginal hp.
I've heard that before but when I ask them to be specific or name a certain part they can't...can you give me an example?
Old 11-23-2005, 03:07 PM
Re: Street Legal HP
if you remove any of your emission control systems or alter them in any way it is illegal. nitrous is also illegal. running leaded race fuel on the highway is illegal. and if you live in Cali im sure there are bunches of other stuff i dont know about
Old 11-23-2005, 05:55 PM
curtis73's Avatar
Re: Street Legal HP
Nitrous is still legal in CA on pre-emission vehicles.
Pimp, I thought you were talking about stock vehicles. The insurance company knows their HP since its published. Aftermarket modifications don't necessarily raise insurance since they don't typically need to be claimed unless you want them to be covered under the policy.
Many aftermarket performance parts are not legal for use on the street. If you have a vehicle that is no longer tested by smog (for instance in CA any 1976 or earlier car or any diesel vehicle) you can do those illegal things since there is no one looking over your shoulder. You can also do these on newer cars in areas that don't test for smog, but be warned that even rural areas are starting smog programs and you may need to undo what you've done.
Cars that still fall under smog jurisdiction can still have aftermarket parts installed as long as they have the proper certification. In CA that means it must be considered either a stock replacement or a performance part which has been proven to not increase emissions. Such parts carry an Executive Order number, often abbreviated as EO. These are certification numbers that are given by CARB (california air resources board)
Old 11-23-2005, 09:28 PM
pimp349's Avatar
So a car could be legal regardless of how much hp it has?
Actually I'm talking about both. For example, if you swap in bigger turbos on a 911, and substantially increase hp, does that make it illegal automatically?.
But how can you have something covered (or even report it openly) if its illegal? Are there specific performance parts that are illegal? For example a rollbar? Seatbelts?
Yes, I've heard that before about emissions...is there anything else though?
Thanks for everyone's response, I really appreciate you taking your time for this.
Old 11-24-2005, 01:22 AM
drdisque's Avatar
drdisque drdisque is offline
Send a message via AIM to drdisque
Re: Street Legal HP
there's nothing inherent to horsepower that makes something illegal.
Dr. Disque -
Current cars:
2008 BMW 135i M-Sport
2011 Mazda2 Touring
Past cars:
2007 Mazda 6S 5-door MT
1999 Ford Taurus SE Duratec
Old 11-25-2005, 08:40 AM
dogbreath077 dogbreath077 is offline
Re: Street Legal HP
There are lots of Legal Hot Rods out there. As long as you comply with the state emission and safety laws you are O.K.
You caninstall a roll bar, no problem. You can shorten your rear end and run wide tires, as long as they have sufficient tread, and don't stick out from the fenders. You can have a low restriction exhaust as long as it is not too loud. You can increase the output of your engine, as long as it passes emmisions and you don't remove any of the factory installed emmision components. Have fun, and buy an exhaust gas analyzer.
Old 11-25-2005, 03:38 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Note that this only applies to the US.
Here in NZ for example a roll cage or bar requires certification, as does modification to things like axles or some changes to the vechiles body work.
